23539 Discussions
[Bug/Feature Request] Erroneous REBAR support warning on older systems - add setting to disable?
Horsemeatburger
I'm currently doing some testing using an Arc A750 in an older Ivy Bridge EP system and found the card performs surprisingly well in a number of benchmarks and games, also compared to a Nvidia RTX 2060 Super.
What's annoying, though, is the "please enable REBAR support for full performance" message that shows up on every boot, despite the fact that this system doesn't support REBAR. What's worse, the Arc Control utility claims that REBAR is supported on my system, despite the fact that it isn't.
While I understand that, on newer systems, it makes sense to tell the user to enable REBAR to get the best possible performance from the card, it's very annoying on older systems which don't support REBAR, and it seems the driver isn't even able to correctly detect when this is the case (there's also the potential to scare away users who bought an Arc card for an older system, which may the card end up being returned).
It would therefore be great if intel could add a setting in Arc Control which allows the user to disable the REBAR warnings.
System: HP z620 workstation (XEON E5-2667 v2 Ivy Bridge EP, 64GB 4x16GB DDR3 ECC Registered RAM, 1.92TB Micron 7300 U.2 NVMe SSD, latest BIOS which is 2.96).
GPU: intel Arc A750 8GB
Arc Driver version: 31.0.101.4502
OS: Windows 11 22H2
Jose_Intel
Hello @Horsemeatburger
Thank you for posting on the Intel️® communities.
I am sorry to hear that you are getting those notifications using the Intel® Arc™ A750 Graphics, and I’ll be more than happy to help you.
I already sent all your feedback and the idea that you have to the corresponding team. We appreciate your time and interest.
Jose B.
Jose_Intel
Jose B.
Jose_Intel
Hello Horsemeatburger
We hope you are having a nice day.
Since we have not heard back from you, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
loicjoachimobg
FYI I have the same issue and it is very annoying haha
