23087 Discussions
Bug Report: Intel HD Graphic driver for Intel Atom X7 display issue on some WPF Applications in Windows 10
BChan21
Referring to this issue: http://stackoverflow.com/questions/32113911/why-wpf-gui-not-showing-on-windows-10 c# - Why WPF gui not showing on Windows 10? - Stack Overflow
The root cause is the GPU driver is not up to date enough to cater a display bug on WPF applications in Windows 10.
For some Intel HD Graphics GPU like HD 4400, the latest driver version 10.18.15.4278 have solved this issue.
However, for Intel Atom X7, the latest driver version for the Intel HD Graphic is still 10.18.15.4248, which the problem still persist.
This create a lot of problem for Atom X7 users, especially those have purchased Microsoft Surface 3 (not Surface pro 3) which is running on the X7 CPU, apparently, nearly all WPF application could not be run normally!!!
so my questions is:
1. is there any way i can download and forcefully install 10.18.15.4278 for those running Atom X7 CPU? I have tried various ways but still, i cannot do it successfully.
2. if not, what is the schedule of releasing a new release so that this bug could be fully catered?
Thank you.
Ricardo_G_Intel1
The Intel Atom x7-Family is a power efficient quad-core SoC for Windows tablets http://ark.intel.com/products/85475/Intel-Atom-x7-Z8700-Processor-2M-Cache-up-to-2_40-GHz Intel® Atom™ x7- Family Specifications. In this case, I suggest checking with the OEM device to get the correct driver.https://www.microsoft.com/surface/en-us/support/browse/surface-3?category=hardware-and-drivers Browse topics for Surface 3
