23832 Discussions
Can i have?
Hiya, in my Advent Modena i currently have Intel Celeron T3100, i was wondering if i could use my Intel Celeron 2.6GHZ in my laptop instead of the T3100?
Thank you.
RGiff
Honored Contributor I
You will have to check chipset compatability and make sure the CPUs use the same socket , Goggle CPU world , ant look up the CPU specs. as far as the chipset you will have to check with intel.
