23535 Discussions
Can't install HD Graphics 530 driver
Januar
Hi there I'm Januar,
Can anyone help me? I just bought a second hand desktop computer with ASRock H110M-HDV motherboard and OS Windows 10.
Since I first started using computer no, the display adapter driver cannot be updated.
I have installed the graphic card 3 times using Intel Driver Support Assistant but it still can't be installed.
Please help... Below I have attached the results from SSU. Thanks a lot in advance
Stefan3D
Januar
I've tried to install this solution but it came up like this..
 any ideas? Thank you
Januar
Thank you..  I'll try this solution
n_scott_pearson
Have you installed the Chipset Device Software package for your motherboard? This package must be installed before ever using iDSA or installing any other Intel driver package. Pre-installation of the Intel Management Engine package is also recommended. Both of these packages are provided by the motherboard manufacturer on their website, not on the Intel site.
You also need to understand something: iDSA is a maintenance tool; it is NOT the tool to do your first installs. As well, there are other prerequisites that must be met before installing or using iDSA. See here for details.
Hope this helps,
