23803 Discussions
Can't install update
Hi guys, I've using A Macbook Pro with Intel HD 3000 built in driver.....and I already using bootcamp to install Windows 7, the reason i installed it just for gaming hehe, and after that i tried to update my graphics driver with windows i've been download the latest update for my graphics driver and when i try to install it....BAM!!!!! The setup won't work properly int say the setup can't install one or more driver...
The question is : What should I do?I want to update it because i think maybe tie update will increase my Macbook performance while gaming
:ANd how to install the update the proper way???
PLEASE SOMEBODY HELP ME......
Marcos_U_Intel
The Intel generic drivers will not work with the Macbook Pro using Microsoft Windows 7 since it is a Macintosh product.
You could try to use the Have Disk/Known File method to install the Intel generic driver from the link below:
http://www.intel.com/support/graphics/sb/cs-022355.htm http://www.intel.com/support/graphics/sb/cs-022355.htm
If the problem persists, you must contact your system manufacturer.
Michael
