23825 Discussions
Can't update Iris Xe Graphics Driver
CRogerBlair
I run Windows 11 Pro on a Dell Inspiron 15 3530 laptop. The Laptop has the following graphics card:
Manufacturer: Intel
Model Iris Xe Graphics
Device ID 8086-A7A1
Revision 5
Subvendor Dell (1028)
Current Performance Level Level 0
Current GPU Clock 300 MHz
Voltage 0.202 V
Driver version 32.0.101.7077
Count of performance levels : 1
Level 1 - "Perf Level 0"
GPU Clock 300 MHz
I keep getting notices to update the graphics driver:
Every time I try the update, I get the following message:
From making notes, I know that the file is gfx-win-101-7080.exe, and the error code is 1000. I don't think it's my network (since this is the only update I have trouble with), and I get the same error message over and over. It was suggested that I turn Core Isolation off and then try to install the update; not only did it not help, but I had to do an in-place reinstall of Windows to reenable Core Isolation.
Has anyone else run into this? If so, how did you fix it?
Mike_Intel
Hello CRogerBlair,
  1. What is the model of your processor?
  2. Let me check, are you also having issues with the graphics and that is the reason why you are updating the driver?
  3. What are the troubleshooting steps that you tried so far?
Michael L.
zabazimbohasan
Hi Mike, could you please review my last post on the forum?
Mike_Intel
Hello CRogerBlair,
Michael L.
CRogerBlair
Unfortunately, I ended up "going nuclear." I tried an in-place restore; that didn't help, so I did a complete rebuild of my system (which took me 3 days to get done. Now, I'm back at work.
Have a great Thanksgiving!
KentRusselP_Intel
Hi CRogerBlair,
I hope you're doing well. I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
