23269 Discussions
Can the HD 4600 run CoD: Advanced Warfare?
MSchm22
Bloack Ops 2 was running pretty smooth (40+ FPS) at minimum settings and a low resolution. Will the HD 4600 IGP be able to run AW too (ofc at the lowest settings)?
Allan_J_Intel1
Thanks for joining the Graphics community.
I am currently researching on this issue. I will update this post as soon as I get any feedback from the engineering team.
Allan.
MSchm22
Ok, I just jumped the gun and bought it. I am running a i3-4100M (+HD 4600) with 2x4GB DDR3-1600 and a SSD. On minimum settings (every off/min) besides Render Resolution (at low, not very low) and textures (normal instead of low) I get around 40FPS with drops to ~30FPS in heavy action. It is playable, but ofc not the best experience. Maybe we can see some improvements in upcoming drivers?
KHans13
That surprises me, the system requirements made CoD:AW look like a game that would only play on mid-range dedicated graphics cards. Goes to show that system requirements are BS Kudos to you! Out of curiosity, are you using low-voltage (1.35V) RAM?
