23807 Discussions
Cannot Connect Second Monitor
NLevo
Good evening to everyone,
I am working on the following machine:
Dell Optiplex 3020
Processor: Intel Core i3 - 4150 CPU @3.50 Mhz 3.50 MHz
Windows 7 Professional
8GB RAM
64-bit
From what i can see in the Computer, there are two outlets for monitors. One is a normal VGA and the other is a DiplayPort.
I amusing the computer with a CQ1859s Compaq monitor connected to the VGA outlet.
I want to use a second - same Compaq - monitor. So i have purchased an adaptor as per http://www.8com.gr/adapter-display-port-male-to-vga-female-18220 Αντάπτορας Display Port Αρσενικό σε VGA Θυληκό (18220) - 8com.gr and try to connect it.
The computer seems to identify the second monitor however there is a blank screen and all the time the monitor is starting and then going to sleep.
Tried to update the drivers but same results.
Any guidance on the above will be highly appreciated.
Allan_J_Intel1
Intel recommends using straight video connections, the usage of adapters may interfere with the graphics multi-monitor functionality because you will be converting digital signal to analog.
You could try first installing the latest video drivers for your graphics controller: https://downloadcenter.intel.com/download/25425/Intel-Graphics-Driver-for-Windows-7-8-1-15-36- Download Intel® Graphics Driver for Windows 7/8.1* [15.36]
http://www.intel.com/support/graphics/sb/CS-033418.htm Graphics Drivers — Intel® Graphics and Televisions Frequently Asked Questions (FAQ)
Allan.
NLevo
Dear Allan,
Thank you so much for your advise. I have tried the link provided but i get the error:
"The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer. Setup will exit"
Afterwards i have tried to find the similar driver through dell. I run the driver detection software in the dell site.
2 drivers are found that should be updated.
- Chipset |Intel 8 Series Chipset Device Software Driver
- Video |AMD Radeon R5-240 / Radeon R7-250 Graphics Driver
The first seems that is installing, and the second one is failing. After the restart and repetition of the same procedure, both drivers are coming back and require updating. it seems that the card cannot connect with the two monitors.
Thanks for the assistance in any case.
Nikos
Allan_J_Intel1
Please bear in mind that once you install a video card on the system, this will electronically disable the on board graphics controller.
It seems to be an issue with the AMD Radeon R5-240 graphics driver.
http://www.amd.com/en-us/products/graphics/desktop/oem/r5 http://www.amd.com/en-us/products/graphics/desktop/oem/r5
Allan.
