23795 Discussions
Cannot enable opengl since windows 10
ccoli2
As above. When I open
Photoshop cc I am given an error message saying that opengl is not enabled. I attempt to enable it by it is greyed out.
PS was working fine 3D and everything before W10. I have updated drivers, or at least I am told I am up to date, but nothing.
This has taken up so much of my time and I really don't know who to ask next?
My Display adapter is marked as:
Intel(R) HD Graphics
No better details are available, or so it would seem.
I am
Toshiba Satellite C50-A-19T,
Windows 10 x64,
4gb ram,
Intel(R) Celeron(R) CPU 1005M @ 1.90GHz
Help would be great.
Stefan3D
You can double-check the OpenGL status with http://www.ozone3d.net/redirect.php?id=401 GPU Caps Viewer or http://www.realtech-vr.com/glview/download.php OpenGL Extensions Viewer
Hello Hobittual:
Please try the driver below, it is version 4425, it is the latest one for the Intel® HD graphics, try to install it manually:
Instructions to install the driver manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Driver 4425:
https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501
The driver above supports openGL 4.0, for Windows® 10, by installing it, you should be able to enable openGL, as you can confirm on the following link:
https://downloadmirror.intel.com/25977/eng/ReleaseNotes_153343.4425.pdf https://downloadmirror.intel.com/25977/eng/ReleaseNotes_153343.4425.pdf
Besides that driver, you can look for the latest graphics version on Toshiba's web site:
http://support.toshiba.com/support/driversResults?freeText=C50-A-19T http://support.toshiba.com/support/driversResults?freeText=C50-A-19T
I looked for the model you gave us: Satellite C50-A-19T, but nothing is showing with that, maybe you can try to verify the model, just to make sure.
Alberto
Hello Hobittual:
I just wanted to check if the information posted previously was helpful for you, and if you need further assistance with opengl or if the problem was resolved?
Alberto
