23279 Discussions
Cannot find "quantization range" in Monitor / TV Settings
I have a HD2000 and a Samsung E8000 plasma TV. I need set hdmi ouput to full RGB mode. but I can't find "Quantization Range" Label in Monitor / TV Settings. there is only a "IT Content" Label.
what's wrong? is there a fix or workaround?
Marcos_U_Intel
In order to assist you further, answer and reply the following questions:
What is your operating system?
What is your graphics driver version?
Michael
from information center
Intel(R) HD Graphics 2000
Report Date: 2/2/2013
Report Time[hh:mm:ss]: 03:48:20
Driver Version: 9.17.10.2932
Operating System: Windows 8 (6.2.9200)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 8099 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 3093 MHz
Vendor ID: 8086
Device ID: 0102
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 2000
Video BIOS: 2111.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 52.36 inches
Vertical: 29.53 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 870 (75 Hz)
1152 by 864 (75 Hz)
1280 by 1024 (75 Hz)
1280 by 720 (60 Hz)
1280 by 800 (60 Hz)
1280 by 1024 (60 Hz)
1366 by 768 (60 Hz)
1440 by 900 (60 Hz)
1600 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 51 09 01 00 00 00
2E 15 01 03 80 85 4B 78 0A EE 91 A3 54 4C 99 26
0F 50 54 BD EF 80 71 4F 81 C0 81 00 81 80 95 00
A9 C0 B3 00 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 A0 5A 00 00 00 1E 66 21 56 AA 51 00 1E 30
46 8F 33 00 A0 5A 00 00 00 1E 00 00 00 FD 00 18
4B 0F 51 17 00 0A 20 20 20 20 20 20 00 00 00 FC
00 53 41 4D 53 55 4E 47 0A 20 20 20 20 20 01 0C
02 03 34 F1 4D 90 1F 04 13 05 14 03 12 20 21 22
07 16 23 09 07 07 83 01 00 00 E2 00 0F E3 05 03
01 72 03 0C 00 10 00 B8 2D 21 D0 08 01 40 07 3F
40 50 90 A0 01 1D 80 D0 72 1C 16 20 10 2C 25 80
A0 5A 00 00 00 9E 01 1D 80 18 71 1C 16 20 58 2C
25 00 A0 5A 00 00 00 9E 01 1D 00 BC 52 D0 1E 20
B8 28 55 40 A0 5A 00 00 00 1E 01 1D 00 72 51 D0
1E 20 6E 28 55 00 A0 5A 00 00 00 1E 00 00 00 A6
* Other names and brands are the property of their respective owners. *
Marcos_U_Intel
Thank you for your fast response.
If the The Extended Display Information Data (EDID) video capability data block indicates that Quantization range is selectable, The Intel(R) Graphics Media Accelerator control panel will show the quantization selection options under monitor/TV settings and it will get applied as well, so pretty much if the option is no there is because is not being detected by the the Extended Display Information Data (EDID).
Check with the monitor manufacturer
Michael
I guess so. but you know, sometimes TV manufacturer give incorrect EDID data, they don't treat these things seriously. I can select Quantization Range (HDMI black level) on my TV, but EDID doesn't show this.
I think that intel should open this option to let user determine what to do. some previous drivers for Vista have this option, AMD's card have this option too.
is there any other workaround? regedit or other way...
Marcos_U_Intel
Unfortunately there is no work around but we do appreciate your feedback. I will forward your feedback to our software support and engineering group to work on future generations of this software that may implement better features. We cannot provide an estimated time for this to happen, but your feedback for sure is important and will be forwarded to higher levels of support.
Thank you one more time for your interest in our products and how to improve their range of features.
Michael
