23555 Discussions
Cannot install 15.36.13.4062
JREMA
I've see that the 15.36.13.4062 drivers are available, but i can't install it on my machine : the installer says " your machine doesn't mean the requiements" (sorry for my bah english), this is my ID hardware for the graphic card and the actual driver :
PCI\VEN_8086&DEV_0A16&SUBSYS_06531028
And driver 10.18.10.3960
Can you please, add this to your drivers ?
JREMA
Up please
Silvia_L_Intel1
Hello Joris_remandet, I would appreciate if you can let me know the model number of your computer or laptop?
Could you please also attach the DX Diag report for your system?
(Start -> Run -> dxdiag -> Save All Information).
I also recommend you to check if you are running the latest BIOS version available for your system.
JREMA
My laptop is a Dell Inspiron 17 5748, i've pass install the driver, but i had to modify the inf file for add my hardware ID, it can say my ID isn't present on this driver
Dell doesn't update our graphics driver, can you add this for the other PC in the driver to pass the install without modding the driver ?
Silvia_L_Intel1
Joris_remandet,
The has been posted to Intel Download Center at the following direct links to the drivers:
32bit https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24592&lang=eng&ProdId=3712 Intel® Download Center
64 bit https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24593&lang=eng&ProdId=3712 Intel® Download Center
Please try the following steps exactly.
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
13. Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS
15. Click "OK"
16. Click "Next", Driver should now be installing.
17. If successful, click "Close", Reboot.
Something very important is that usually OEMs make a lot of customizations to the drivers and the installation of Intel's drivers could overwrite those customizations. Therefore it will affect your system.
JREMA
Intel released a new driver with the number 4080 (if my memory is good), after uninstall the 4061 which i've modified, the new driver 10.18.14.4080 is installed. I think it's a bug which is corrected in the new version.
Silvia_L_Intel1
Thanks for the information Joris_Remandet.
Please let me know, is your system working fine after the installation of the new driver?
JREMA
My computer works fine with this new driver
Silvia_L_Intel1
Great!! Thanks for the feedback.
