23539 Discussions
Cannot update Driver to 15.33.22.64.3621
HAhn
Hello, I have been trying to update my driver for quite a while now. The computer continues to give me a "not compatible with current operating system", when the INTEL Download Center says that it is compatible with Windows 8.1.
To clarify,
Driver Product: http://www.intel.com/support/graphics/intelhdgraphics4000 Intel® HD Graphics 4000
Current Driver Installed: 10.18.10.3304
Newer Driver: 15.33.22.64.3621
http://https//gist.github.com/anonymous/cc01355f14bbfa79e4de Here are my computer specs
Thank you for your time!
Silvia_L_Intel1
Hello Ahjpeace, you may want to try installing the latest Graphics driver available Version 3945.
Intel® Iris™ and HD Graphics Driver for Windows* 7/8/8.1 32bit
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24328 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24328
Intel® Iris™ and HD Graphics Driver for Windows* 7/8/8.1 64bit
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329
Bear in mind that we provided generic drivers; therefore sometimes these cannot be installed on OEM systems or the installation of them could overwrite OEMs customizations and possibly change the functionality of the graphics.
I would recommend using only the system manufacture drivers, however, if you are still want to install our drivers, you may try forcing the installation by performing manual procedure, however I cannot assure you they are going to work as expected.
See here for instructions: http://support.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer manufacturer graphics driver detected
