23586 Discussions
Change resolution after driver install but before reboot?
Dvand1
Hi all!
I've got a question for all you graphics (drivers) experts.
A situation overview:
At the hospital where i work we've changed procedures and operating systems.
Centralized IT made an image (w7) for the guest-speaker computers in the learning environment on which on first boot we're able to make changes, but on second boot the installation locks its configurations and we can change diddlysquat. When I install my graphics drivers for certain systems it requires a reboot and after the reboot i'm supposed to choose the right resolution. The big problem is that after the reboot the configuration is locked and if i select the right resolution, the system forgets this after a reboot or system shutdown.
Is there a way to change the standard selected resolution before a reboot? (regedit, reg file or something similar)
Or maybe delete all the resolution options except for the one i need?
Is it possible to do this for multiple monitors?
We use different hardware and different drivers. The drivers i'm testing with are:
____________________________________________________________________________
Production Version Releases
Microsoft Windows Vista* 64
Microsoft Windows* 7 64
Windows* Embedded Standard 7 64
Driver Revision: 15.17.19.64.2869
October 18, 2012
* NOTE: This document refers to systems containing the
* following Intel(R) chipsets:
* Intel(R) B43 Express Chipset
* Intel(R) G41 Express Chipset
* Intel(R) G43 Express Chipset
* Intel(R) G45 Express Chipset
* Intel(R) Q43 Express Chipset
* Intel(R) Q45 Express Chipset
* Mobile Intel(R) GL40 Express Chipset
* Mobile Intel(R) GM45 Express Chipset
* Mobile Intel(R) GS40 Express Chipset
_________________________________________________________________________________
Hope this makes any sense to you all.
Thanks in advance!
cheers,
Daan
Kevin_M_Intel
Hello hamandeggs,
If you select the correct resolution and apply settings from the Intel® Graphics Control Panel the system should keep those changes and you should be able to reboot the system and the same resolution set before the restart should be applied.
Here you can find some examples from other forums where customers are providing feedback on this:
http://www.tomshardware.com/forum/170178-46-display-resolution-setting-registry http://www.tomshardware.com/forum/170178-46-display-resolution-setting-registry
http://www.dreamincode.net/forums/topic/16430-changing-screen-resolution-without-the-gui/ http://www.dreamincode.net/forums/topic/16430-changing-screen-resolution-without-the-gui/
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Perhaps other users in this community can share their feedback on this topic.
Kevin M
