23748 Discussions
Clone display command under Windows XP
JMull7
I work on computer equiped with an Intel Core i7-620UE, under Windows XP (yes it's possible ).
I search a solution to activate "clone" or "extended" mode with a command line or by code. I can't use graphical interface to do it.
I know since Windows 7 there is "DisplaySwitch.exe" to do this, but under Windows XP I have found nothing.
Someone know a solution to do this ?
Hello JBM
Thank you for joining the community.
As you mentioned Windows® XP is not supported by this processor, however, please provide the following information to investigate the case:
What is the hardware/software that you have installed on your system?
What are the steps that you have performed in order to find a solution to this problem? Please provide step by step.
Leonardo C.
Hello JBM
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
