23525 Discussions
Collage mode - Intel NUC i7 RX Vega Hades NUC8I7HVK2
KJako5
I just bought a Intel NUC8I7HVK2, because I have 4 monitors that I want to display a full screen video (collage mode). But collage mode doesn't seem to be an option in Intel Graphic Command Center? I tried to download the old Intel Graphic Control Panel, but its unable to launch, because "None of the displays are using Intel Graphic drivers". Is collage mode not possible anymore?
LeonWaksman
In your NUC, you may use Readeon Settings panel to use multi display configuration in collage Mode: https://www.amd.com/en/support/kb/faq/dh-014#faq-AMD-Eyefinity-Overview
Leon
KJako5
Hi LWAKSMAN.
Thanks, it worked!
I didn't have the Radeon Settings Panel, and the AMD Driver Auto detect Tool said :"no compatible components found...".
So I tried to download a driver manually, and that worked!. So now I have the Radeon Settings Panel and Collage Mode(Eyefinity) works perfect!
Thx again - much appreciated!
LeonWaksman
  1. I'm glad that it is what you have looked for.
  2. In the left bottom corner of the Radeon Panel you may click an "Updates" and then check for updates. You will have the latest driver installed.
  3. Check also the "ReLive" function. It gives you possibility to record video from the screen https://www.amd.com/en/support/kb/faq/relive-install
  4. You should update drivers from Intel Download page. Most important is to download and install the Chipset and Management Engine Drivers: https://downloadcenter.intel.com/product/126143/Intel-NUC-Kit-NUC8i7HVK . On this page you may find also the Radeon driver, however, in old 18.12.2 version.
  5. It is important to update Bios to the latest 058 version.
Leon
KJako5
Thanks for the tips​.
Intel Driver Assistent says that all drivers is updated, but i'll chek it 👍.
