23852 Discussions
Color Saturation not adjusting
pcman
I have a new HP Envy w/intel graphics and the color saturation (in the intel graphics command ctr.) doesn't change anything.  The slide lever moves and shows numbers,  but color intensity does not change. Updated drivers - no change.  Help please.
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
n_scott_pearson
Depending upon the monitor in question, I have seen the sliders appear to do nothing as you move them but, when you click on Apply, the changes are then applied. Check this for your case.
pcman
Yesterday there was a bios update.  The problem w/slider saturation now works.
Thanks for replies.
