23801 Discussions
Color profile switching
DirtyCurtis
attached is my build list. im having an issue on startup with my intel graphics command centers color profile being set in application but almost seems to lack priority seeing how my monitor will appear 70% darker than it should be set to. When i change the profile slightly then set it to the saved default color profile will stay set until next reboot. please help
build listbuild list
DirtyCurtis
Solved myself. Iris takes priority over command center.
ACarmona_Intel
Hello DirtyCurtis,
To further investigate, may I know when the issue started? And I just wanted to confirm, are you using the color management settings in Windows?
Furthermore, please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, etc. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
Carmona A.
ACarmona_Intel
Hello DirtyCurtis,
Regarding our case, I am following up to check if you already have the answers to my questions so I can further analyze our issue.
I will be waiting for your response!
Thank you for your understanding, and have a great day.
Carmona A.
DirtyCurtis
ACarmona_Intel
Hello DirtyCurtis,
Thank you so much for the update. I'm happy to hear that you have already resolved our issue in this case.
I also appreciate you sharing the solution with me.
Since you will no longer need my assistance, I will now be closing our case today. If in case you would like to post again in our community, please submit a new question, as this thread will no longer be monitored.
Have a great day!
Carmona A.
