23800 Discussions
Command and conquer 3, hd 4600
JGonz25
I tried to run the game today and it gave me the "exception in exception handler" error. I tried "updating" the intel driver and it worked once, I closed the game and a few hours later I tried to play it again and the same error appeared. I updated to the latest driver but no change...
Any ideas?
Attached is my system specs saved from the HD graphics control pannel
Henry_A_Intel1
Hello Cu3rvo;
Thank you for your inquiry.
I am sorry for the problems at hand. But could you please provide us with more information.
This HD 4600 is part of what model system.
Also when playing the game are you using the internal display or external display.
Which graphic driver version are you running.
Also the most import what error message are you getting when trying to play the game.
Regards;
Henry A.
JGonz25
Thank you for responding
Its on a i7 4790K on an asrock extreme 6/3.1 motherboard
the error that the game displays is exception in exception handler error
driver version 10.18.15.4279
I'm on windows 10
Henry_A_Intel1
Thank you for the information
But checking the web site of the motherboard
http://www.asrock.com/mb/Intel/Z97%20Extreme63.1/ http://www.asrock.com/mb/Intel/Z97%20Extreme63.1/
I will need to ask which video card are you using.
Could you please send me a copy of the log from dxdiag.
JGonz25
no extra video card, why would I ask with help on the 4600HD if I had an alternate video card? From what I've searched the problem is exactly with the intel video cards. Since I don't have an extra video card I'm stuck with trying to look for solutions in order to play the game.
Henry_A_Intel1
Hello Cu3rvo;
I am sorry if you think the question is incorrect but we need to cover all aspects.
But checking the DxDiag you are running Driver File Version: 10.18.0015.4279 (English) Driver Version: 10.18.15.4279
Then please do the following:
Regards;
Henry A.
JGonz25
I don't know what's the matter with the driver version, the link you provided is the last diver I installed, it says 15.40.7.64.4279, I downloaded it and installed it and the actual driver says 10.18.0015.4279
SJoe
Hi Henry,
I have the same issue with C&C on Windows 7 and Windows 10 with new installations. My computer's motherboard is ASUS Maximus VI Formula with HD4600, and I have no entra graphic card installed. The C&C just gives some exceptions.
While I could play C&C on lenovo's laptop HD4500 with Windows 8.1.
After I googled this issue, I found that GFX_Win7_8_8.1_64_15.33.24.64.3643 works with C&C on Windows 10's HD4600. But the response is quite slow.
Hope this info. could help.
Cheers,
Walker2016
EstebanA_C_Intel
Hello All:
I would like you to test the behavior of the game with the following drivers:
https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Please advise with the results.
Note: Beta drivers are for testing which means that are still under development and not complete yet. For this reason we cannot assure they will work flawlessly.
Esteban C
ES_1
Hello all,
I have similar problems with Command & Conquer 3, Command & Conquer Red Alert 2 (incl. Yuri's Revenge) and Command & Conquer Generals with an Intel HD 4600 GPU. Mine is on a Intel Core i7 4790K processor. I also have Windows 10 x64 Threshold 2 installed. I have no additional graphics card. I was able ton run the game - but not with the latest drivers and I'd like to share my experiences.
I have used the Intel Driver Update utility, which gave me the following driver: https://downloadcenter.intel.com/download/25188/Intel-HD-Graphics-Driver-for-Windows-10-64bit-3rd-Gen-BYT- Download Intel® HD Graphics Driver for Windows® 10 64bit (3rd Gen & BYT) Please note: This driver is for the 3rd generation processors, but mine is 4th generation! With this driver I am able to play Command & Conquer flawlessly.
Unfortunately, Windows Update updates the driver everytime because of newer versions. The Intel Driver Update Utility also wants to install this driver: https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] (the same as mentioned above). With this driver I cannot play any of the games. It results to a black screen when I launch the game. I can hear the music, click sounds in the menu, but I cannot see anything.
Last, I tried the beta driver: https://downloadcenter.intel.com/de/download/25541/Intel-Beta-Grafik-Treiber-f-r-Windows-7-8-1-10-15-40- Download Intel ® Beta Grafik-Treiber für Windows ® 7/8.1/10* [15.40] I hoped that this driver will fix the issues. It also doesn't work. I have the same issues with the official driver.
So the only working driver is the one for the 3rd generation Intel processors - I don't recommend an installation. But it may help intel to find the difference between both drivers.
norbyte
EstebanA_C_Intel
Hello norbyte:
Thank you for the workaround provided.
This could help, but may affect the behavior of the system while using the graphics driver for another generation of processors.
Esteban C
AHorn6
I have the same problem of Command and Conquer 3 crash at start on Intel HD 5300, system details below.
Lots of pages on the internet list this as an intel driver bug. Can you fix?
Intel(R) HD Graphics 5300
Report Date: Thursday, August 11, 2016
Report Time [hh:mm:ss]: 10:44:32 AM
Driver Version: 20.19.15.4463
Operating System: Windows* 10 Home (10.0.10586)
Default Language: English (United States)
Physical Memory: 8094 MB
Vendor ID: 8086
Device ID: 161E
Device Revision: 09
Graphics Output Protocol (GOP) Version: 5.5.1033
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) M-5Y10c CPU @ 0.80GHz
Processor Speed: 998 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5300
Shader Version: 5.0
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 11.42 inches
Vertical Size: 6.69 inches
Supported Modes
1920 x 1080 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF 2D 21 00 00 00 00
00 17 01 04 95 1D 11 78 02 92 27 98 58 52 95 26
1F 4D 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 1D 36 80 A0 70 38 1E 40 30 20
8E 00 25 A5 10 00 00 18 00 00 00 0F 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 FE 00 41
55 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 42 31 33 33 48 41 4E 30 32 2E 31 20 0A 00 06
* Other names and brands are the property of their respective owners.
EstebanA_C_Intel
Hi, Alex1996:
Have you tested this with the beta driver?
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=84188 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40
Please let me know how it goes and what is the behavior your system has.
Esteban C
AHorn6
Hi Esteban C,
I see the same problem with the beta driver. System details after the beta install below.
Regards, Alex
Report Date: Friday, August 12, 2016
Report Time [hh:mm:ss]: 10:24:19 PM
Driver Version: 20.19.15.4474
Vendor ID: 8086
Device ID: 161E
Device Revision: 09
Shader Version: 5.0
Active Displays: 1
Gamma: 2.2
Maximum Image Size
Supported Modes
Raw EDID:
EstebanA_C_Intel
Thank you for the answer and information provided, Alex1996.
I will be sending this matter over to get it reviewed and possibly replicated (attempt to)
As soon as I get an update, I will let you know.
Esteban C
Hi, All:
After digging deeper in other forums, I found out that some people have fixed this by installing a previous version of the Intel HD Graphics drivers.
I know is kind of tricky to test previously released drivers, but if you have the chance, please try it out and let me know, with that we can find out a solution for this matter
Previous drivers are noted on the download page of all the drivers.
https://downloadcenter.intel.com/download/25188/Intel-HD-Graphics-Driver-for-Windows-10-64bit-3rd-Gen-BYT- Download Intel® Graphics Driver for Windows® 10 [15.33]
Hope I can hear findings from your end guys.
Esteban C
AHorn6
I tried to install the 15.33 driver but it wont install on my HD 5500 laptop, it says "This computer does not meet the minimum requirements to install this software". I guess this is because the driver is too old to run on HD 5500.
The oldest driver I could find on the intel site that would install on HD 5500 is https://downloadcenter.intel.com/download/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?product=86210 Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 10 64-bit Version: 15.40.4.64.4256 (Previously Released) Date: 8/5/2015
15.40.4.64.4256 driver has the same exception issue as the latest driver Version: Beta 15.40.26.4474 (Latest) Date: 6/24/2016
Thank you for your answer, Alex1996.
Please use the manual install and make sure the device is not connected to the intenet while following that installation method.
Windows 7*: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html
Windows 10*: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Please let me know how it goes.
Additionally, was the problem present in previous versions of Windows?
Esteban C
JFazz1
I am having the same problem as the above user. (Alex)
i followed the manual install instructions and I received a message
"Windows has determined the driver software for your device is up to date"
thanks - John
EstebanA_C_Intel
Hi, jfazz1023:
Thank you for letting me know about that, would you please provide me with the Intel® System Support Utility report from the system that has the issue?
How to get that report?
-Go to: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility
-Download the utility
-Scan your system with the utility
-Export the report (hit next and then save) and attach it to your answer with the advanced editor option (reply button and then check upper right corner)
Hope I can hear from you soon.
Esteban C
JFazz1
Thanks EstebanC
I ran the report and saved it. It should be attached to this message.
Thank you!
