23806 Discussions
Contrast Enhancement resets in Intel® Graphics Command Center
zzghr
in default video settings it is turned on and greyed out, in custom video settings Intel® Graphics Command Center resets this option to ON after program restarts, other settings stay OFF (noise reduction, film mode, etc...).
system report attached
AlHill
This is a laptop, correct?
If so, use the drivers from your laptop manufacturer.
Doc
zzghr
no, this is personally assembled Desktop PC
this issue is also discussed before, I believe this might be a bug: https://forums.intel.com/s/question/0D50P00004JFr1qSAD/cannot-disable-contrast-enhancement
regards
AlHill
Download, run, and ATTACH (using the paperclip) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
zzghr
here it is
Leonardo_C_Intel
Hello zzghr
  • Can you try completing a video showing step by step how to reproduce the behavior that you are having for me to test it on my end?
  • Please try uninstalling the Intel® Graphics Command Center and installing the latest version available in Microsoft store.
Leonardo C.
A Contingent Worker at Intel
zzghr
video attached, I already did uninstall/install completely with drivers a couple of times...
Leonardo_C_Intel
Hello zzghr
Thank you for sharing the video and reporting this behavior, we are going to investigate it, as soon as we have news we will be posting back.
Leonardo C.
Leonardo_C_Intel
Hello zzghr
Thank you for waiting.
This issue has been fixed already and will be included in the next official release of Intel® Graphics Command Center. The fix is already in the Beta release that can be obtained from here: https://www.microsoft.com/en-us/p/intel-graphics-command-center-beta/9nmr79ztjftc?activetab=pivot:overviewtab
Hope this helps
Leonardo C.
Leonardo_C_Intel
Hello zzghr
Have you been able to test the Intel® graphics command center provided?
Leonardo C.
Leonardo_C_Intel
Hello zzghr
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Leonardo C.
