23272 Discussions
Crysis Warhead flickering smoke bug report and "solution" of this problem.
Parapele
Yes at this time smoke. I swear, almos ever single game i run have grafical bugs, and now i gona make a list. If your settings "Particles Quality" not "Minimum" in some area smoke starts flickering, yea this is solution. Mainstream, gamer, enthusiast - cause flickering.
I attached save file where it occurs. Here screenshots how it looks like https://imgur.com/a/2zpnD Crysis Warhead flickering smoke bug - Album on Imgur . Windows 10 64bit i3 6100 HD 530 driver 4590. GOG version feb 3 2009 v1.1.1.711 Save goes C:\Users\"YOURNAME"\Documents\My Games\Crysis_WARHEAD\SaveGames
UPD: Goddammit, Crysis have the same problem! https://imgur.com/a/aV64Q Crysis "smoke" bug - Album on Imgur I was thinking why original game dont have this bug in DX9 mode...To fix it you need set "Particles Quality" set to "low" Game from GOG Version Mar 11 2008 1.1.1.6156 I attached save file for original game. File goes C:\Users\"YOURNAME"\Documents\My Games\Crysis\SaveGames
UPD2: Game suffers from another bug, if you set "Objects Quality" higher that "Mainstream" (DX10 and DX9) you will get something looks like very aggressive lod bug. Demonstration DX10 & DX9 on "Gamer" https://gfycat.com/TangibleFavorableHoverfly https://gfycat.com/TangibleFavorableHoverfly https://gfycat.com/NeatBigIbadanmalimbe https://gfycat.com/NeatBigIbadanmalimbe Here DX10 and "Mainstream" https://gfycat.com/PoorPlaintiveCatbird https://gfycat.com/PoorPlaintiveCatbird
Parapele
Here save file for "LOD" bug.
Hello Parapele,
Thank you for contacting the Intel community.
Have you tried to completely uninstall the driver and then reinstall it, is your BIOS up to date?
In addition, I will really appreciate if you could fill out the information at the following link and post it here:
/thread/77761 https://communities.intel.com/thread/77761
Ivan.
Parapele
And "almost every single game i run have graphical bugs" it figure of speech that showing current state of intel drivers. Crysis/Warhead 2007/8 game, 10 years old. Thousands of people tried play game and NOBODY reported about of bugs, this is tell us something. And what i supposed "fill out" it's joke. Form to be filled does not consider the problem - "AC or DC mode, i.e. is power cable plugged in or not?" oh yeah it will helps. System Support Utility already grab all information what we need. I first person who did not pass by and did not say - it just intel drivers. Crysis and Warhead has complex of bugs, i give all information, what, where, settings, saves. Just grab the links and start to fix bugs, and Seriously it's depressing.
Parapele
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Crysis and Warhead shares couple of bugs - flickering grass (DX10 mode only) and flickering smoke if your settings "Particles Quality" not "Low" for Crysis and "Minimum" for Warhead. Smoke supposed to be come from static objects like buildings or already placed destroyed cars by dev. design, plus you need to be close. Warhead has exclusive bug if you set "Objects Quality" "Gamer" (DX10 and DX9) or higher that you will get flickering on some objects as rocks and trees - depends from point of view and you need to be stay close.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
custom GIGABYTE H110M-S2H i3-6100
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
only HD 530
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
SAMSUNG SyncMaster 204B
How much memory [RAM] in the system (see note2 below).
8Gb DDR4 2133
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
Hardware Stepping (see note1 below).
<td style="border: 0px solid black; ...
Thank you for taking your time to help us with this information, we will further investigate these bugs that your are reporting.
Ivan.
Parapele
Thanks Ivan for your attention to the problem. I want apology for my reaction. I spent like 4 hour on crysis and warhead messing with settings, google, youtube, forums.... Suggestion "uninstall the driver and then reinstall it" for me was like evil sarcasm. I not a newbie, i use a PC since Pentium 133 MHz. Plus trying explain on english its additional frustration for me. I was really angry because people know about this bugs for years and nobody report.
I made additional video of bugs. On all video Warhead first map - "Call me Ishmael" everything on video it's 5-10 min. of gameplay from a start.
"Grass bug"
DirectX 10
https://gfycat.com/CheerfulRepulsiveJapanesebeetle https://gfycat.com/CheerfulRepulsiveJapanesebeetle
"Smoke bug"
"Particles Quality" "Mainstream"
https://gfycat.com/FreeLongHarborseal https://gfycat.com/FreeLongHarborseal
https://gfycat.com/RigidImaginaryIndianspinyloach https://gfycat.com/RigidImaginaryIndianspinyloach
"LOD bug"
https://gfycat.com/SelfassuredFilthyEgret https://gfycat.com/SelfassuredFilthyEgret
This is screenshots DX10 vs DX9, the same settings 1:1. Just open screenshots in new tabs and switch fast between them. Long distance view scene, look how many vegetation missing on DX10 render. This is how it's supposed to be? Maybe it's part of problem.
https://i.imgur.com/W4gZLxN.jpg https://i.imgur.com/W4gZLxN.jpg
https://i.imgur.com/IrPi66M.jpg https://i.imgur.com/IrPi66M.jpg
Plus what i noticed, a time where LOD bug happens FPS drops really serious, 45 vs 30, only difference i move mouse to the right to bug appear, watch screenshots.
https://i.imgur.com/uiJKsd4.jpg https://i.imgur.com/uiJKsd4.jpg
https://i.imgur.com/W722sXF.jpg https://i.imgur.com/W722sXF.jpg
Thank you for this information, just to have more information and to report this problem and I apologize if you already try this but would you please try older driver versions?
https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Version: Beta 15.40.xx.4539
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Version: 15.40.28.4501
https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-?product=88345 Version: 15.40.14.4352
Ivan.
Parapele
Hi Ivan, i try them and now i have NSFL content for you, because when i close my eyes i see flickering and horrible things \^_^/ I spent another 2 hours and now i real specialist if it Crysis and Intel iGPU. I'm pretty sure nobody on whole planet not test so many Crysis Warhead with so many different drivers and settings before. Here tests (from old to new) 4352, 4501, 4539, 4590 versions of drivers. I made tests on all settings in DX10, DX9 only enthusiast - it twice a more work. And I am ready to show some of them. Oldest driver 4352 12/23/2015 and now we can see what a progress in driver was made (spoiler alert! not a lot). Everyone who will watch it - open wide your eyes, this is will be painful, especially in extra section. Settings i change with dev. presets. DX10 doesn't have smoke bug, no matter how old or new driver - only DX9 bug, but grass...
4352 driver enthusiast preset Smoke bug DX10 https://gfycat.com/FirstSpottedAllosaurus https://gfycat.com/FirstSpottedAllosaurus vs DX9 https://gfycat.com/ParallelSlimyBear https://gfycat.com/ParallelSlimyBear
4501 driver enthusiast preset LOD bug DX10 https://gfycat.com/DangerousEvilAfricanpiedkingfisher https://gfycat.com/DangerousEvilAfricanpiedkingfisher vs DX9 https://gfycat.com/InstructiveSlowKingsnake https://gfycat.com/InstructiveSlowKingsnake
4539 driver enthusiast preset Grass bug DX10 https://gfycat.com/ConfusedDazzlingHawaiianmonkseal https://gfycat.com/ConfusedDazzlingHawaiianmonkseal vs DX9 https://gfycat.com/GaseousAcrobaticAnchovy https://gfycat.com/GaseousAcrobaticAnchovy
Now extra section, check this out. Yes it's a different type of bugs. On some video you can see the jet, yes that triangle appear from jet plane, he 1 km away.
4352 driver https://gfycat.com/PartialSerpentineCobra https://gfycat.com/PartialSerpentineCobra https://gfycat.com/GleamingGraciousAlleycat https://gfycat.com/GleamingGraciousAlleycat https://gfycat.com/WhiteClumsyBull https://gfycat.com/WhiteClumsyBull
4501 driver https://gfycat.com/CreepyFaroffCardinal https://gfycat.com/CreepyFaroffCardinal https://gfycat.com/DimWelloffAracari https://gfycat.com/DimWelloffAracari https://gfycat.com/UnconsciousTenderBoa https://gfycat.com/UnconsciousTenderBoa
4539 driver https://gfycat.com/VengefulShamefulCoyote https://gfycat.com/VengefulShamefulCoyote https://gfycat.com/WigglyGrandioseChicken https://gfycat.com/WigglyGrandioseChicken https://gfycat.com/DescriptiveMammothIrishsetter https://gfycat.com/DescriptiveMammothIrishsetter
Okay, maybe last driver will be better...
4590 driver https://gfycat.com/VictoriousFamiliarIchthyostega https://gfycat.com/VictoriousFamiliarIchthyostega https://gfycat.com/AcclaimedSpanishFattaileddunnart https://gfycat.com/AcclaimedSpanishFattaileddunnart https://gfycat.com/EasyRectangularAtlanticbluetang https://gfycat.com/EasyRectangularAtlanticbluetang
NOPE! You probably thinking - what the hell i just watched. And how i constantly can reproduce it, and how i find this. Well i find this while testing old drivers and different settings, from screenshots you probably noticed i'm playing on old monitor and for 16x9 i need window mode, plus that easy for me use another programs. Crysis interesting game - windows key not working, and alt+tab you can do only if you have another program - i use notepad. Windows 10 has button on right bottom - minimize all. That's a button of problem for Intel driver and Crysis. Okey dokey, how reproduce. Run game in DX10 mode - yes DX9 don't have this bug (at least i not can make it), set preset enthusiast, load your save, go to the menu, minimize game, get back and set mainstream preset - PROFIT!? And now when you start feeling boring get back and set enthusiast preset again - second PROFIT!? Also you can play with fps while you playing fps. Game can run much better (recording eat 10 fps) but if LOD bug appear its - 50% of fps, catch em all!
Thank you for all this information and for taking your valuable time to test these drivers.
There is a new Beta driver that it was released on 2/23/2017, would you please try this Beta driver and let me know the results?
https://downloadcenter.intel.com/download/26604/Graphics-Intel-Graphics-Driver-Beta-15-45-?product=88345 https://downloadcenter.intel.com/download/26604/Graphics-Intel-Graphics-Driver-Beta-15-45-?product=88345
This driver is provided as a beta test driver. While it has had limited validation testing by Intel, it is essentially a test driver and is not to be considered a permanent replacement for a fully validated and certified graphics driver.
Ivan.
