23683 Discussions
Custom resolution 400x300
KKass1
Hi
I am trying to set a custom resolution to 400x300 or 480x320) without success
My Configuration:
Windows 10
Intel HD Graphics 2500
I am going to Custom Resolutions and adding these resolutions with success, but when I go to display settings -> Advanced Display Settings -> Display Adapter Properties -> Liste All Modes, the addes resolutions are not showing.
If I add for exemple 544x960 is working
Is there "low" limit for the resolution I can set?
Thank you
Thank you very much for taking the time to reach the Intel Communities Team, khkassem.I will do my best to assist you further.
Indeed, there is a limit on the resolution that can be set to a display. For you to double check that you need to generate an https://www.intel.com/content/www/us/en/support/articles/000005848/graphics-drivers.html Intel® HD Graphics Report. Open the .txt file generated, copy the Raw EDID section and paste it in this Web Based EDID Reader: http://www.edidreader.com/ http://www.edidreader.com/
You will be able to see in the Timing Bitmap section of the EDID reader The maximum and the minimum resolution supported by your system.
Please understand that Custom Resolution is not supported and the results may vary. This can be harmful to your system and to your display.
Third party links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Antony S.
Hello, khkassem.
I would like to know if you still need assistance. If so, please do not hesitate to reply back.
Antony S.
