23665 Discussions
Custom resolution absence
MatGo
I have a 12th Gen Intel(R) Core(TM) i7-12650H. My Intel(R) UHD Graphics driver version is 31.0.101.4314, and in the Intel graphics command center app in the display section there is no possibility to set neither custom resolution nor stretched regime. Can someone suggest how to fix this issue. Or how to set a stretched display regime having this issue.
Alberto_R_Intel
MatGo, Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
For this scenario and in reference to your question, it is important to mention that after an update to the Intel® Graphics Command Center (build 1.100.2765.0) some options will no longer appear or are missing under the Scale dropdown menu, including the stretched option. Here you will find additional details on this matter:
https://www.intel.com/content/www/us/en/support/articles/000057700/graphics.html
Regarding the custom resolution, just in case, you can confirm "How to Set Custom Resolutions and Modes in Intel® Graphics Command Center" in the following link:
https://www.intel.com/content/www/us/en/support/articles/000056144/graphics/legacy-graphics.html
Continuing with this topic, we just wanted to confirm:
What is the model of the laptop?
Was the custom resolution feature working fine before on this specific machine?
If yes, when did the issue start?
Did you make any recent hardware/software changes that migh tcause this problem?
Which Windows* version are you using?
https://www.intel.com/content/www/us/en/support/articles/000057926.html
Albert R.
Alberto_R_Intel
Albert R.
tokinamu
I don't understand why did you delete such option. It makes everything harder or impossible :)))))))
