23832 Discussions
CustomModeApp.exe, Broken again with Windows 10
MMunr1
I am using an ZOTAC NANO CI320 as an HTPC. It uses the Intel HD Graphics from the Celeron N2930. I have it attached via HDMI to a 73" DLP TV. In windows 8, I finally was able to run CustomModeApp.exe and make up a resolution with no overscan issues. However. To this day non of the drive GUI functions for scaling or custom resolutions are available, even though screen shotted in your own help pages.
I tried Windows 10 when it was released this summer and had the same issue. Which was promised to be fixed.
Now it's December, same issue. Not fixed.
I need a straight answer (no thread hijacks about games) can I correct my HDMI overscan or not in windows 10?
Intel(R) HD Graphics
Report Date: Wednesday, December 2, 2015
Report Time [hh:mm:ss]: 1:50:26 AM
Driver Version: 10.18.10.4252
Operating System: Windows* 10 Pro Insider Preview (10.0.10586)
Default Language: English (United States)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 3974 MB
Processor: Intel(R) Celeron(R) CPU N2930 @ 1.83GHz
Processor Speed: 1833 MHz
Vendor ID: 8086
Device ID: 0F31
Device Revision: 0E
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics
Graphics Output Protocol (GOP) Version: 7.2.1005
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
Serial Number: ONK0c41
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 63.78 inches
Vertical Size: 35.83 inches
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 720 (60p Hz)
1360 x 765 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (30p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (60i Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 3D CB 41 0C 00 00 00 00
00 16 01 03 80 A2 5B 78 2A 70 85 AB 4E 48 AB 26
0F 50 54 21 08 00 D1 C0 8B C0 81 80 81 C0 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 50 8D 63 00 00 1E 01 1D 80 18 71 38 2D 40
58 2C 45 00 50 8D 63 00 00 1E 00 00 00 FC 00 54
58 2D 4E 52 34 31 34 0A 20 20 20 20 00 00 00 FD
00 3B 3D 0F 44 11 00 0A 20 20 20 20 20 20 01 2F
02 03 3A F1 48 90 22 20 05 04 03 07 01 38 09 7F
07 0F 7F 07 17 07 50 3F 06 C0 4D 02 00 57 06 00
5F 7E 01 67 54 00 83 4F 00 00 6C 03 0C 00 11 00
B8 2D C0 00 00 00 00 E2 00 7F 01 1D 80 3E 73 38
2D 40 7E 2C 45 80 50 8D 63 00 00 1E 01 1D 80 18
71 1C 16 20 58 2C 25 00 50 8D 63 00 00 9E 01 1D
00 72 51 D0 1E 20 6E 28 55 00 50 8D 63 00 00 1E
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31
* Other names and brands are the property of their respective owners.
MMunr1
I need an straight answer. Windows 10 is useless on this HTPC machine if I can't correct the HDMI overscan. I might as well just revert to windows 8 again.
Allan_J_Intel1
At this stage, there is no ETA for a resolution on this issue, this has been escalated through engineering level. We are just waiting for new drivers at: https://downloadcenter.intel.com/ Intel® Download Center
Allan.
