23806 Discussions
D82085 and ADD2
The motherboard has VGA and DVI video outputs onboard. I have a monitor connected to each port to get a dual monitor display. If I install an ADD2 card will both onboard ports stay active so I can use 3 monitors?
Allan_J_Intel1
Hi there!
If you are using an Intel onboard graphics and an ADD2 card you will have only 2 monitors at same time... The Intel graphics controller is dual pipe; this means that supports couple of monitors.
I hope that helps...
Allan.
