23525 Discussions
DCS WORLD 2.9 MULTIPLAYER ARC B580 POOR PERFORMANCE
PMADDD
Hello, i've ordered the Arc B580 Titan luna OC 12gb GPU and im having issues running DCS MULTIPLAYER (version 2.9.24.20232)
On singleplayer i am getting good fps, from 70-100fps+, while on multiplayer no matter the module used i get 10-25fps, yes i've tried lowering settings or increasing them i have ran the game with and without FSR or NIS, also i have reinstalled the drivers using DDU, there seems to be a memory leak or something wrong with the drivers. Im currently using the latest drivers (version 32.0.101.8531) but it also happened in the previous driver. There has been a case of the game working for 5 minutes on multiplayer but it would go back to poor performance and stay that way without recovery. I will also mention that i have a 49gb pagefile applied. The server i usually join on DCS is named -= dcs-online.de =- (ip 212.91.237.145:10315), Module used in screenshots is su25-T (i think the least demanding module in DCS)
One thing to note is, if you load into any multiplayer server and the leak happens, it will persist in singleplayer until you restart the whole process completely.
I have attached screenshots of my setup, the settings in game, and the 2 scenarios, one on multiplayer with low FPS in su25t, and one on self hosted multiplayer server with a heavy mission with good FPS 70+ ( multiple moving units, air ground and infantry being all simulated on my pc)
(posted it before on the forums wich i think was the incorrect place for it)
BuenoS_Intel
Hi PMADDD,
Thank you for reaching out and providing such detailed information about the performance issues you're experiencing with your Arc B580 Titan Luna OC 12GB GPU in DCS World multiplayer.
I understand you're getting excellent performance (70-100+ FPS) in single-player mode, but experiencing significant frame rate drops (10-25 FPS) in multiplayer environments, which suggests a potential driver-related issue or memory leak as you've mentioned.
To help us better diagnose and resolve this issue, I'd like to request the following additional information:
  1. Could you please capture 3 separate CapFrameX measurements of the game's FPS performance, each running for 5-minute intervals (300 seconds)? This will help us analyze the performance patterns and identify any specific bottlenecks or memory-related issues.
  2. Please run an SSU (Intel® System Support Utility for Windows*) scan of your system and provide the results. This will give us comprehensive information about your hardware configuration, driver versions, and system state.
  3. Does this performance degradation occur on specific maps or with particular aircraft modules, or is it consistent across all multiplayer scenarios regardless of the map/aircraft combination?
Your observation about the issue persisting in single-player after experiencing it in multiplayer until a complete process restart is particularly valuable information that will help our engineering team investigate this further.
Thank you for your patience, and I appreciate your detailed reporting. Once I receive this additional data, we'll be better positioned to identify the root cause and work toward a resolution.
Bueno S.
PMADDD
Hello BuenoS
1.  I have captured 3 separate measurements, first consisting of su25-T during a memory leak on a contention server on map caucasus(~30fps), second of su25-T after restart with same position same flight path and map consisting of normal fps(80-130fps) for a certain period of time, and third consisting of SU25-T memory leak switching into singleplayer the dogfight scenario where fps is around 30-40 and the leak persisting into singleplayer. (They are in a zip format because the website doesn't allow json format to be uploaded)
2. I have attached specified file
3. I cant test other maps because of low storage space, but it has occured on caucasus map so far. once the leak happens it persists into other modules, so no matter the module the leak will keep on going,on a different occasion i tested it by switching from su25-T to the A-10 to f-16 and the issue persisted with fps being as low as 10 on the a-10 module and f-16. So yes its consistent regardless the scenario/map and spawn positions on said maps as well
BuenoS_Intel
Hi PMADDD,
Thank you for your response and for providing the detailed information.
I will carefully review and attempt to replicate the steps based on the information you have shared in order to further investigate the issue. Your input is very helpful in assisting us with the troubleshooting process.
Thank you for your cooperation and patience. I will keep you updated should there be any findings or if additional information is required.
Bueno S.
BuenoS_Intel
Hi PMADDD,
Thank you for your patience while waiting for the update and thank you for reporting this issue. Our priority is to target the most popular games and apps to focus our efforts on providing a high quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout this year and beyond. While we can’t accommodate your request at this time, please watch on our website for any possible changes to this situation.
I will now close this inquiry. If you require further assistance, please submit a new request, as this thread will no longer be monitored.
Bueno S.
