23769 Discussions
DVI not working Intel HD Graphics 2500
I have a Asus P8H61-M LE motherboard with Intel HD Graphics 2500 and I'm using my VGA port to connect a monitor. Few days ago I've bought an DVI to VGA adapter so I can use my DVI port to connect a second monitor that have a VGA connaction, but it doesn't work, the computer doesn't show that have been any connaction, and theres nothing on the second screen.
What to do?
Noam
NICHOLAS_F_Intel
Hi noam.n,
You have one monitor connected via VGA to the VGA port on your motherboard, and another monitor connected via VGA-to-DVI into the DVI port on the motherboard - is that correct?
The motherboard (according to this link; http://www.asus.com/Motherboards/P8H61M_LE/# gallery ASUS - P8H61-M LE) has a DVI-D input connection. This means that it only accepts a digital display connection, so using an adapter on a VGA (VGA = analog) will not work. You need to get a DVI-D cable to connect between your display and motherboard for it to activate.
Let me know if you have any other questions,
-Nic
