23832 Discussions
Dedicate Video Memory Bios - What's The Point
MJone10
There is an option in bios to increase dedicated video memory to 1gb max.
I know that the intel gpu dynamically adjusts video memory based on need.
So why is there an option in bios to set a fixed amount of video memory?
Hello MartyJones,
Thank you for contacting Intel Communities.
In this case, the answer will depend on the applications that you will run in the system, as some of them won't be able to run with the BIOS default settings, then, you are allowed to modify the max amount of dedicated memory (up to 1GB).
You can check the following thread for further information:
/message/338219# 338219 Is it possible to increase the amount of dedicated video ram?
Hope this information helps.
Please don't hesitate in replying to this post if you need further assistance.
Juan Carlos
Hello MartyJones,
I was reviewing this thread and I wanted to know if you need further assistance.
Please don't hesitate in replying to this post if you need additional information.
Juan Carlos
MJone10
Hi, thanks for the help. This issue is now resolved.
Hi MartyJones,
Thanks for the update.
Please don't hesitate in contacting us back if you need further assistance.
Juan Carlos
even my video memory is 32 mb and the maximum is 1792 how do i increase it to maximum i tried so many things but nothing happened
Hello sakshi_1008,
In this case, I recommend you to contact the system manufacturer in case you have an OEM system, if you built your computer, then contacting the motherboard's manufacturer, this because all BIOS are different and system configurations differ from a system to another.
Juan Carlos
