23851 Discussions
Default profile keeps loading HD 2000
Hi, i was hoping someone could help me.
I have 2 Dell vostro 360's and ive plugged a 2nd monitor into the rear to extend the desktop which works very well.... until you reboot.
Once it reboots it comes back to the clone desktop settings?
Ive tried saving the profile this works for 2 reboots then goes back to the same cloned desktop again, i updated the drivers, this made no difference, i tried to find the default profile settings in the registry but failed to find anything?
Can anyone help me?
Here is my systems details:
Intel(R) HD Graphics 2000
Report Date: 10/3/2012
Report Time[hh:mm:ss]: 10:30:04
Driver Version: 8.15.10.2761
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United Kingdom)
DirectX* Version: 11.0
Physical Memory: 2985 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1300 MB
Graphics Memory in Use: 114 MB
Processor: x86 Family 6 Model 42 Stepping 7
Processor Speed: 2494 MHz
Vendor ID: 8086
Device ID: 0102
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 2000
Video BIOS: 2089.0
Current Graphics Mode: 1280 by 1024
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: Generic PnP Monitor
Display Type: Analog
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 10.63 inches
Monitor Supported Modes:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1A B3 65 05 C8 58 05 00
20 0F 01 03 68 22 1B 78 2A 3D B5 A3 56 4B 99 25
15 50 54 A5 4B 00 81 80 01 01 01 01 01 01 01 01
01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
13 00 54 0E 11 00 00 1E 00 00 00 FC 00 41 31 37
2D 31 0A 20 20 20 20 20 20 20 00 00 00 FD 00 38
4C 1E 53 0E 00 0A 20 20 20 20 20 20 00 00 00 FF
00 59 45 45 50 33 35 30 34 30 38 0A 20 20 00 2C
* Built-in Display *
Display Type: Digital
Gamma Value: 2.2
Maximum Image Size:
Horizontal: 20.47 inches
Vertical: 12.60 inches
1920 by 1080 (60 Hz)
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 0D 12 08 06 70 03 00 00
15 15 01 04 A5 34 20 78 EA 80 42 AC 51 30 B4 25
10 50 53 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 94 34 80 64 70 38 1F 40 10 20
5A 00 FD 1E 11 00 00 1C 00 00 00 F7 00 0A 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FD 00 38
4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC
00 32 33 22 20 41 49 4F 0A 20 20 20 20 20 00 D8
* Other names and brands are the property of their respective owners. *
Still awaiting an answer on this, can anyone help?
NICHOLAS_F_Intel
Hi resrudeby,
This is a lack of persistence. It is controlled by the OEM (in this case Dell), via the VBIOS. Contact your OEM support site and make sure your BIOS is up to date. Your driver already appears to be. If this doesn't work, you should contact your OEM support directly with the issue.
-Nic
