23854 Discussions
Device not started in windows device manager
Podaen
Is this normal?
SSU report
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) UHD Graphics 770"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) UHD Graphics 770"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=UHD+Graphics+770"
CoInstallers:"oem50.inf,iRPLSD_w10_DS,Internal,Intel(R) UHD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"06/15/2023 02:00 am"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_3b3ce26993cf233b\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.4502"
INF:"oem50.inf"
INF Section:"iRPLSD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"<>,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3b3ce26993cf233b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3b3ce26993cf233b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3b3ce26993cf233b\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_A780&SUBSYS_7D911462&REV_04\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"120 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) UHD Graphics Family"
Stefan3D
@Podaen wrote:
Is this normal?
It is not normal.
Scroll down and click the last event at the bottom to expose the actual error.
Then review this article:
https://support.microsoft.com/en-us/topic/error-codes-in-device-manager-in-windows-524e9e89-4dee-8883-0afa-6bca0456324e
Podaen
Thanks man, Really helpful!
I suspect the error code is "Problem Status: 0xC00000E5" ? If I am right, the code E5 in dec. is 16. This is the information I found for code 16
Full Error Message
“Windows cannot identify all the resources this device uses. To specify additional resources for this device, click the Resources tab and fill in the missing settings. Check your hardware documentation to find out what settings to use. (Code 16)”
Cause
The device is only partly configured and might need additional manual configuration of the resources the device requires.
Recommended Resolution
The following steps might only work if the device is a Plug and Play device. If the device is not Plug and Play, you can refer to the device documentation or contact the device manufacturer for more information.
  1. From Start, search for device manager and select Device Manager from the results.
  2. Double-click the device in the list, and choose the Resources tab.
  3. In the Resource Settings list, check to see if there is a question mark next to a resource. If so, select that resource, and assign it to the device.
  4. If a resource cannot be changed, click Change Settings. If Change Settings is unavailable, try to clear the Use automatic settings check box to make it available.
This the information in my resources
Memory Range 0000006000000000 - 0000006000FFFFFF
Memory Range 0000004000000000 - 000000400FFFFFFF
I/O Range 4000 - 403F
IRQ 0xFFFFFFCC (-52)
The change settings seems unavailable and I don't know where to find this info...
https://www.intel.com/content/www/us/en/products/sku/230493/intel-core-i513600k-processor-24m-cache-up-to-5-10-ghz/specifications.html
Some additional info from me... I recently saw in the Arc Control App that some information was missing in settings, system info. Things like GT frequency, GT memory frequency, Memory bandwidth and Bus width/interface. Not sure, but maybe it helps.
 2023-07-11 14_46_47-Device not started in windows device manager - Intel Community — Mozilla Firefox.png
n_scott_pearson
Seriously? No, E5 is not 16.
Error 0xc00000e5 usually means that prerequisite executable file(s) is/are either corrupted, infected, or not properly installed.
Podaen
I did a lookup what GT memory means and this is what I found
GT memory from an iGPU is the memory that is used by the integrated graphics processor (iGPU) of a CPU. It is usually shared with the system memory (RAM) and depends on the memory speed and configuration. Different iGPUs have different amounts of GT memory and performance.
I recently set my sticks to an uncompressed format. Could it be that this is the problem?
These are my sticks (dual channel)
https://www.gskill.com/specification/165/393/1661410171/F5-6000J3038F16GX2-TZ5N-Specification
Podaen
The uncompressed memory wasn't the problem.
@n_scott_pearsonYour right... Bin to fast with google. 🙂 Thanks!
I will try to install it to safe mode.
Podaen
I don't know anymore what to do. I am out of ideas
I disabled windows securtity features
Disconnected from internet
removed arc control
removed driver inf files manualy (one by one)
downloaded the DDU removal tool
boot in to safe mode and run the tool
reboot in normal mode
preformed a clean installation of the intel driver
still the device is not started with the Intel driver... The basic driver from windows does
2023-07-11 17_21_14-Intel(R) UHD Graphics 770 Properties.png2023-07-11 17_21_30-Intel(R) UHD Graphics 770 Properties.png
n_scott_pearson
Have you installed the Chipset Device Software and Intel Management Engine packages?
Podaen
The mobo chipset I did... the Intel Management Engine packages not sure, I will look in to that. thanks!
Podaen
Nah, for sure something is preventing the device to start...
And it seems that it is not the only one that doesn't start
But what does it actualy mean because, my display is working (except the black border around it) and I have audio. The information I get is very limited from the device manager.
If I look at the SSU report... many things are unavailable too.
Hugo_Intel
Hello Podaen
Thank you for posting on the Intel Communities. We are sorry you are experiencing error messages on the device manager.
If I might jump into the conversation, we would like to add that in case you are not experiencing any type of issues on your system's graphics behavior these messages can be ignored since they can happen when Windows has detected that a device's status changed.  Unless there is a yellow exclamation mark in Device Manager, there should not be any issues with the driver or system.
Hugo O.
Podaen
No yellow marks so I think it is OK.
Hugo_Intel
Hello Podaen
Please let us know if you need further assistance or have further questions related to this topic.
Hugo O.
Hugo_Intel
Hello Podaen
Thank you for letting us know. If there are no yellow marks in the device manager, everything should be ok on your system. Please let us know if you have further questions related to this topic or if we should go ahead and close this thread.
Hugo O.
Hugo_Intel
Hello Podaen
I see there are no further questions related to this topic so we will proceed to close this thread. Feel free to open a new topic If you need further assistance.
Hugo O.
