23649 Discussions
Discrepancy in Intel Core Ultra 5 125H GPU Specifications
Samadhan
According to the official product brief for the Intel Core Ultra series, Intel Arc GPUs are listed as available on select H-series processors.
Ref Intel® Core™ Ultra Processor (Series 1) Product Brief
However, upon reviewing the hardware details for my system equipped with the Intel Core Ultra 5 125H, the GPU detected is the integrated Intel Meteor Lake-P graphics ( Intel Graphics ), and there is not an Intel Arc GPU.
Here are the CPU details for my system:
root@DEB-NUC14RVS-S7ARYZ00E2517BL:~# lscpu
Architecture:             x86_64
  CPU op-mode(s):         32-bit, 64-bit
  Address sizes:          46 bits physical, 48 bits virtual
  Byte Order:             Little Endian
CPU(s):                   18
  On-line CPU(s) list:    0-17
Vendor ID:                GenuineIntel
  BIOS Vendor ID:         Intel(R) Corporation
  Model name:             Intel(R) Core(TM) Ultra 5 125H
    BIOS Model name:      Intel(R) Core(TM) Ultra 5 125H To Be Filled By O.E.M. CPU @ 4.2GHz
    BIOS CPU family:      1
    CPU family:           6
    Model:                170
    Thread(s) per core:   2
    Core(s) per socket:   14
    Socket(s):            1
    Stepping:             4
    CPU(s) scaling MHz:   17%
    CPU max MHz:          4400.0000
    CPU min MHz:          400.0000
    BogoMIPS:             5990.40
    Flags:                fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm p
                          be syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aper
                          fmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 s
                          se4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb inte
                          l_ppin ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep
                          bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect av
                          x_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni
                           vaes vpclmulqdq rdpid bus_lock_detect movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabili
                          ties
Virtualization features:
  Virtualization:         VT-x
NUMA:
  NUMA node(s):           1
  NUMA node0 CPU(s):      0-17
Vulnerabilities:
  Gather data sampling:   Not affected
  Itlb multihit:          Not affected
  L1tf:                   Not affected
  Mds:                    Not affected
  Meltdown:               Not affected
  Mmio stale data:        Not affected
  Reg file data sampling: Not affected
  Retbleed:               Not affected
  Spec rstack overflow:   Not affected
  Spec store bypass:      Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:             Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:             Mitigation; Enhanced / Automatic IBRS, IBPB conditional, RSB filling, PBRSB-eIBRS Not affected
  Srbds:                  Not affected
  Tsx async abort:        Not affected
Here are the GPU details for my system:
root@DEB-NUC14RVS-S7ARYZ00E2517BL:~# lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Graphics] (rev 08)
        DeviceName: Onboard - Video
        Subsystem: ASUSTeK Computer Inc. Meteor Lake-P [Intel Graphics]
        Kernel driver in use: i915
root@DEB-NUC14RVS-S7ARYZ00E2517# lspci
00:04.0 Signal processing controller: Intel Corporation Meteor Lake-P Dynamic Tuning Technology (rev 04)
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 10)
00:07.2 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #2 (rev 10)
00:08.0 System peripheral: Intel Corporation Meteor Lake-P Gaussian & Neural-Network Accelerator (rev 20)
00:0a.0 Signal processing controller: Intel Corporation Meteor Lake-P Platform Monitoring Technology (rev 01)
00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 10)
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 10)
00:0d.3 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #1 (rev 10)
00:12.0 Serial controller: Intel Corporation Meteor Lake-P Integrated Sensor Hub (rev 20)
00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20)
00:14.3 Network controller: Intel Corporation Meteor Lake PCH CNVi WiFi (rev 20)
00:16.0 Communication controller: Intel Corporation Meteor Lake-P CSME HECI #1 (rev 20)
00:17.0 SATA controller: Intel Corporation Device 7e63 (rev 20)
00:1c.0 PCI bridge: Intel Corporation Device 7e3c (rev 20)
00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20)
00:1f.3 Multimedia audio controller: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20)
00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20)
00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20)
01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. NV2 NVMe SSD SM2267XT (DRAM-less) (rev 03)
56:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
Given that the Intel Arc GPUs are supposed to be available for H-series processors as per Intel’s documentation.
Ref :
Intel Core Ultra 5 Processor 125H 18M Cache up to 4.50 GHz Product Specifications
Intel® Core™ Ultra Processors (Series 1)
It seems there might be a mismatch or issue with either the documentation or the hardware configuration.
Could you please clarify:
1. Whether Intel Arc GPUs are indeed available with the Intel Core Ultra 5 125H processors, or if this was an error in the documentation?
Samadhan
Hi JedG
After further investigation, I discovered that Intel ARC Graphics will only be fully activated in a dual-channel RAM configuration.
When my system was configured with a single-channel RAM (32GB), it operated with standard Intel HD Graphics.
However, after adding an additional RAM module to create a dual-channel setup, the system now correctly recognizes the Intel ARC Graphics.
Why is this critical information not mentioned in the documentation?
It would be beneficial for users to know that the performance and features of Intel ARC Graphics are dependent on the RAM configuration.
Thank you for your assistance, and I look forward to your response.
JedG_Intel
 Hello Samadhan,
Thank you for posting at Intel Community Forum
I understand that you have a concern about the specification of the Intel Core Ultra 5 125H processor. For me to have a better understanding of your system components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I look forward to your response!
Jed G.
Samadhan
Hi Jed,
Thank you for your prompt response. I have downloaded the Intel System Support Utility as you suggested and generated the report. I’ve attached the log files to this message for your review.
Please let me know if you need any additional information.
Looking forward to your assistance!
Samadhan
JedG_Intel
Hello Samadhan,
Thank you for sharing the SSU logs.
Upon checking, the device you are reporting is an OEM product. Having said this, the computer manufacturer may have altered the features, incorporated customizations, or made other changes to the device. I highly recommend that you get in touch with our OEM about this so they can provide you with the information that you need.
I hope you find this information helpful.
Jed G.
Samadhan
Hi JedG
JedG_Intel
Hello Samadhan,
I appreciate your effort in providing us this information. I would like to highlight that the device you are reporting is OEM and the manufacturer might have made changes, hence why we suggested to get in touch with them.
Additionally, configuring the RAM module to dual channel setup was also mentioned on this link. It mentioned that Intel Arc GPUs are only available with systems powered with at least 16GB of system memory in a dual channel configuration.
Furthermore, we will still investigate on this concern to provide you with more information. Once we have additional information to share, we'll let you know.
Thank you so much!
Jed G.
JedG_Intel
Hi Samadhan,
After checking internally, we have more information to share with you.
Intel notes related to graphics type for this CPU say "Processor Graphics indicates graphics processing circuitry integrated into the processor, providing the graphics, compute, media, and display capabilities. Other Intel® Core™ Ultra processor-powered system configurations feature Intel® Graphics. Check with OEM or retailer for system configuration details. Intel® Iris® Xe Graphics only: to use the Intel® Iris® Xe brand, the system must be populated with 128-bit (dual channel) memory. Otherwise, use the Intel® UHD brand."
Meanwhile, ASUS specs site for this NUC say:
"Intel® Arc™ GPU (Core Ultra)*,
Intel® Graphics (Core3),
*Intel® Arc™ GPU requires using 2 x SO-DIMM"
If these requirements are fulfilled then correct name and functionality should be enabled.
I hope that this additional information helps. If you have further concerns, let me know so I can address it.
Jed G.
Samadhan
Hi JedG,
Thank you for sharing this additional information.
Due to the lack of clear instructions from the sellers, we were initially unaware of these specific requirements, and we couldn’t find these details in the official documentation at first.
Later we also consulted with ASUS and local dealers of Intel Core Ultra processors for ASUS NUCs. They have now updated their official website to reflect that Intel Arc graphics indeed require dual-channel memory.
ASUS also provided us with their official documentation, which confirms that Intel® Arc™ Graphics requires a dual-channel memory configuration (2 x SO-DIMM) to function. In systems using only single-channel memory, the graphics default to Intel UHD Graphics.
You can review the full details in the [ASUS NUC 14 Pro Plus Technical Specifications]
We have tested and confirmed this behavior on the ASUS NUC 14 Pro+ model (NUC14RVS-B). When using a single RAM module, the system displays Intel UHD Graphics, but with dual-channel memory, it enables Intel® Arc® Graphics.
Additionally, we came across an Intel article that addresses a similar issue with Intel Iris Graphics.
[Intel Article on Iris Graphics]
Thank you so much for your support in this matter.
Samadhan
JedG_Intel
Hello Samadhan,
I'm thankful for your effort and initiative to contact ASUS to gain more clarity on the issue. I'm also glad to hear that ASUS was able to update their documentation to avoid confusion from others.
With all this information shared, I can therefore say that the issue is resolved. If you have other concerns, let me know so I can help you with it.
Have a great day!
Jed G.
JedG_Intel
Hi Samadhan,
I'm just following up to see if we can close this thread. If you don't have other questions or concerns, let me know so we could proceed accordingly.
Jed G.
Samadhan
Hi Jed G,
Thank you for following up.
As discussed earlier my issue has been already resolved.
I really appreciate your help in getting this sorted out.
You can go ahead and close the ticket.
Samadhan
JedG_Intel
Hello Samadhan,
I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
