23851 Discussions
Display Driver Stopped Responding and Has Recovered
RŁyźn
Hello all.
For about two weeks I'm occuring that problem. This graphics issue sometimes end with blue screen of death with error "VIDEO_SCHEDULER_INTERNAL_ERROR" and laptop is restarting.
Sometimes when using videos on YT/Facebook everything freezes, then goes:
and after it everything is going well.
OS - Win10
Intel HD Graphics 520
v. 20.19.15.4360
What can I do to fight this issue?
Thanks for any help.
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/88355/Intel-HD-Graphics-520 Downloads for Intel® HD Graphics 520
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
RŁyźn
OK, I tried to do everything manual and after I try to choose the file from Graphics and "OK" it says, that the specified folder do not contains a proper driver for this device.. blah"
Stefan3D
Stefan3D
You are using an out-dated version 10586 of Windows 10.
Current drivers require "Anniversary update" or newer as stated in Installation_Readme.txt
Check out https://en.wikipedia.org/wiki/Windows_10_version_history Windows 10 version history - Wikipedia
RŁyźn
Ok, here it is
RŁyźn
K, updated it to version 1709.
RŁyźn
It seems that the problem is gone. Thanks a lot, You are the great one!
