22965 Discussions
Display Driver for windows 8.1 has stopped responding and has recovered
AVali
When I close laptop (closing the lid doesn't send laptop to hibernate or suspend it) and open it again I see black screen in 2 seconds and then I see the message Display Driver for windows 8.1 has stopped responding and has recovered
DxDiag.txt
System Information
Operating System: Windows 8.1 Professional 64-bit (6.3, Build 9600) (9600.winblue_rtm.130821-1623)
Language: Russian (Regional Setting: Russian)
System Manufacturer: Dell Inc.
System Model: Dell System Inspiron 7720
BIOS: A15
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8048MB RAM
Page File: 2307MB used, 5741MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_05781028&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD02DA
Native Mode: 1920 x 1080(p) (60.012Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3282 (English)
Driver Version: 10.18.10.3282
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 8/30/2013 01:32:54, 12078592 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-3B79-7525B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x05781028
Revision ID: 0x0009
Driver Strong Name: oem12.inf:5f63e5341859ec8c:iIVBM_w81:10.18.10.3282:pci\ven_8086&dev_0166
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Name: NVIDIA GeForce GT 650M
Device ID: PCI\VEN_10DE&DEV_0FD1&SUBSYS_05781028&REV_A1\4&274689E5&0&0008
Kevin_M_Intel
Hi VAV0001,
It is important to say that the drivers we provide are generic drivers for OEM computers. This is because we just provide the hardware to the computer manufacturers and they will design and create their custom drivers for their units. However, we do have generic drivers for your system. My best recommendation is to install the latest generic BETA driver we have for the graphics controller. You can get at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23194 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23194
As piece of advice, I recommend you doing a power cycle on the unit by removing the battery and pressing the power button for about 20 seconds and after that you may try installing the driver above. In case that it is not working, my best recommendation is to contact Dell so they can help you out with their custom driver.
TBock
I have the same problem with our HP 630 / Celeron b800 notebooks with Intel HD 2000 graphics.
Driver crashes after hibernate then has recovered. But tabs in chrome no longer respond
as their tasks crash.
Is there a beta driver for this model also?
It's only with windows 8.1, windows 8.0 had no issues.
Thank You
PInfa
Hi -- I have same problem. Did you find a fix?
AVali
No. I still use generic driver from Windows Update. But It happens rarely. I don't know why. And I didn't try to install generic beta driver
PInfa
Which is the 'generic' driver?
TBock
this will not install on Celeron b800
got another?
Kevin_M_Intel
Hi Timo2,
I am afraid to say that there are no drivers for Win 8.1 for your graphics controller at this point.
TBock
The problem is caused by a third party software called F.LUX ( justgetflux.com ).
I have notified the developer.
Thank You.
