23833 Discussions
Display Driver intel HD Graphics Drivers for Windows 8(r) stopped responding and has Successfully Recovered
AEssa3
is there any fix for this? its been doing this a lot recently even though i updated my drivers through the intel update utility the problem still continues. please do help solve this problem
I am using a dell Inspiron 15 3537
Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz
Display Adapters AMD Radeon HD 8850M & Intel(R) HD Graphics Family
Intel(R) 8 Series Chipset Family SATA AHCI Controller
Amy_C_Intel
Hello azee
I would recommend to install the latest version of the Graphics Driver which according to your system information it's at the following link https://downloadcenter.intel.com/download/25232/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64bit Download Intel® Iris™, Iris™ Pro, and HD Graphics Driver for Windows* 7/8/8.1 64bit, I would also recommend performing a manual installation of the driver. Here are the instructions for the Manual Installation http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
For further information you can check the following link http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft*.
Let me know your findings.
Amy.
AEssa3
Hello
Sorry I forgot to mention i am using windows 10 although i got an update for drivers which do not include windows 10
i got the same driver update on the Intel Update Utility
Amy_C_Intel
Try with the following driver https://downloadcenter.intel.com/download/25308/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-4th-Gen-Windows-10-64bit Download Intel® Iris™, Iris™ Pro, and HD Graphics Driver for 4th Gen Windows* 10 64bit.
Here is a helpful that might help you to fix this issue;
http://www.drivethelife.com/windows-drivers/how-to-fix-display-driver-stopped-responding-and-has-recovered-on-windows-10-8-7-xp-vista.html How to Fix the "Display Driver Stopped Responding and Has Recovered" Error | Drive The Life.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
DC5
I have the same problem , windows 10 upgrade , acer intel core i7-6700hq . None of the downloads in the link appear to be for 7th gen ?
Amy_C_Intel
Please try with the following driver https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen- Download Intel® Graphics Driver for Windows® 7/8.1/10* [15.40 6th Gen].
DC5
Amy_C_Intel
Do you mean the driver installation or do you mean that the error still persists?
DC5
The driver wont install as I have an i7 and there is only i6 on that download. I noted a lot of people with i7 having the same problem so I think its safe to assume the issue is not resolved
Amy_C_Intel
I apologize, I provided you with the wrong driver version. Please try with the following https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] , download the zip. version and I would recommend installing the driver with these instructions;
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
13. Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS
15. Click "OK"
16. Click "Next", Driver should now be installing.
17. If successful, click "Close", Reboot.
DC5
Tried this , it does not work . Same problem occurred immediately after reboot.
Amy_C_Intel
At this stage this issue under investigation, please keep on checking the https://downloadcenter.intel.com/ Drivers & Software for future driver releases.
DChan27
I think it's important for this issue to continue to be investigated.
I have the same problem: Dell XPS. Bought it in 2015. Top of the line, latest specs. Windows 10 64 bit
After long hours with Dell tech support, unable to resolve. I finally went to Device Manager and used the automatic driver update option. It downloaded the latest driver automatically and installed it and the problem got better significantly. It used to do it at least a few times a day with heavy usage but after downloading the update, I no longer had the problem. I thought it was fixed actually but today it happened again. First time in about a week.
Note I did not update the driver MANUALLY as instructed but merely clicked the automatic option.
After the error came up tonight, I went back to the Device Manager but this time, clicking on the option shows I already have the latest driver version installed.
Not quite sure what to make of this but the fact that an updated driver update did significantly improve the problem for me shows me that it is something with the Intel driver and how it interacts with Windows 10.
Please continue to research this and give us a driver update that fixes this issue.
I don't play games on my computer so luckily this problem is mildly annoying as it resets my browser when it happens but bounces back reasonably quickly, but for heavy gamers, this is a deal breaking issue.
rsonk
Check the status of graphics card from Device Manager.
a. Click on Start button, type devmgmt.msc and press Enter.
b. Locate the graphics device, right-click http://goo.gl/hwzlvP on it and select Properties.
c. Click on General tab and check for device status.
if your pc has onboard intel video and a gpu you have the video cable on the intel motherboard port. for the error a lot of games dont like intel or other video chipset. you can try updating the gpu driver from intel web page and the mb chipset drivers.
Please do try these driver from Intel's Support site that may work.
- First, uninstall Intel graphics driver from Device Manager.
- Download and install these driver
- After the installation reboot your laptop and see if this will solve the issue for good.
