23854 Discussions
Display adapter
Shashankgarg78
Hi I have intel i5 processor and intel dh61ww motherboard and window 10 operating system
Intel hd graphics not showing in my pc
It is showing microsoft low resolution display adapter
What is the fault in it why graphic driver is not showing
And what is the sollution of getting rid from it
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
n_scott_pearson
Your processor is not supported on Windows 10. Intel did not produce graphics drivers for Windows 10 for these processors. You are using the Microsoft compatibility driver currently -- and, as you have found, it has performance and compatibility issues.
The only thing that you can do, if you truly want to continue to use this system, is add a graphics card. I recommend that you purchase an older NVIDIA card (there are unexplained compatibility issues with AMD cards).
Hope this helps,
