22883 Discussions
Displayport on UHD Graphics not working for 2nd monitor but HDMI is working on first
optyk
New ASUS V500MVC with i5-13420H and Intel HUD Graphics: No signal from the Displayport.
Driver from Intel installed: 32.0.101.7026 dated 19 august 2025.
First monitor connected to HDMI with a HDMI to HDMI cable (works also with a HDMI to DVI-D cable).
Second monitor connected to DisplayPort with:
1a)  adapter DisplayPort to HDMI and a HDMI to HDMI cable: not working;
1b) adapter DisplayPort to HDMI and a HDMI to DVI-D cable: not working;
2a) Adapter DisplayPort to HDMI with the same cables as for the first adapter: not working;
2b) Adapter DisplayPort to VGA with a VGA to VGA cable: not working.
All these cables were tested and were OK.
The 2 adapters are brand new.
Windows does not detect a second monitor.
HELP: 1) Can this integrated Intel UHD graphics operate 2 monitors?
2) if yes, how can the DisplayPort be activated?
Scan file of the system by Intel App is attached.
MUC
Honored Contributor I
According to the ASUS user manual, no special steps are required to use both video outputs.
HDMI and DisplayPort use different transmission protocols. There may be a compatibility issue with the adapters. Please provide a web link for the two adapters you intend to use.
You will have the least problems if you use a straight connection (DisplayPort > DisplayPort). Does either monitor have a DisplayPort input?
optyk
On monitor #1, i have DVI-D and VGA connexion, on #2, I have DVI-D, VGA and HDMI.
My adapters are: 1) https://addison-electronique.com/en/displayport-male-to-hdmi-female-adapter-15-cm.html
and 2) https://addison-electronique.com/en/displayport-male-to-hdmi-dvi-vga-female-adapter-29-cm.html
Thanks for looking at my problem.
If i do not find a solution, I will have to go back o BestBuy to get help.
MUC
I would connect the HDMI monitor directly using an HDMI cable.
For the other monitor, you can try this:
Club 3D CAC-1012 DisplayPort to VGA Cable M/M 2m/6.56ft
While it's not the cheapest solution, it should work up to 1920 x 1080 pixels thanks to active protocol conversion.
optyk
Thanks. I will try to find one in my area because delivery time is estimated at 4-7 weeks.
I will report as soon as possible.
regards
optyk
Finally I went at Bestbuy ans They tried the displayport ans confirmed it was not working. They sent me a new one but it has exactly the same problem. I will return it friday and buy another brand.
