22965 Discussions
Does UHD 630 support 120Hz Monitors over HDMI 1.4?
AntonisCy
Hello.
Can someone please let me know if my PC can run a monitor resolution 1920x1080 at 120Hz?
I am currently running a monitor with resolution 1920x1080 at 60Hz but i want to change it to a newer monitor that can run 120Hz.
Here is my system :
Operating System
Windows 11
Computer type
PC/Desktop
Manufacturer/Model
Lenovo ideaCentre 510-15ICB
CPU
Intel i3-8100 CPU @ 3.60GHz
Motherboard
Intel B360
Memory
1 x 4GB 2666 Mbps SAMSUNG M378A5244CB0-CTD
Graphics Card(s)
Integrated Intel UHD Graphics 630
Sound Card
High Definition (HD) Audio, Realtek® ALC233 codec
Monitor(s) Displays
Samsung SyncMaster 2494HS (HDMI)
Screen Resolution
1920 x 1080 @ 60Hz
Hard Drives
1TB HDD
Browser
Chrome
Roland_87
Sure:
  1. You described you're using HDMI 1.4. This version specifies the maximum bandwidth, resolution and Hz that can be put through.
  2. The Intel HD630 supports up to 4K resolution: Intel Specs
Of course there is no full guarantee at this point. But all specs do point to being able to play Full HD on 120Hz. Beware that it will take more performance of this onboard GPU. It will be less suitable for gaming.
Roland_87
On 1920x1080 with HDMI 1.4: you can get up to 120Hz. But that is the maximum of your HDMI port and graphics card.
Source: https://glenwing.github.io/adapters/?output=HDMI
AntonisCy
@Roland_87  thanks for the reply. Can you please explain how you used the info in the link to determine that my setup can actually support 1920x1080 at 120Hz?
Roland_87
Sure:
AntonisCy
@Roland_87 thanks. I do not intend of playing any games. And i think the GPU with the help of the 16GB RAM will be enough for OS browsing and internet surfing.
