23526 Discussions
Doom (2016) Crashing with Intel HD Graphics 4600?
JDink
Hi, I'm a bit confused. The thread at shows that the issue should be fixed, but it is still crashing for me like before the issue was resolved for others. The output from Intel System Support Utility is attached.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Doom (2016) crashes a few moments after launching.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%):
Hardware (HW)
Brand and Model of the system.
HP Envy 15t-j100
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP
How much memory [RAM] in the system (see note2 below).
12 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
N/A
Hardware Stepping (see note1 below).
See attached...
CCris2
New Contributor II
Hi IHateJava ,
Can you try this driver also ? https://downloadcenter.intel.com/download/26682/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product=80939 Download Intel® Graphics Driver for Windows* [15.40]
If it doesn't work with that one then is a driver problem, because I have a similar problem with the last driver on Intel HD 530, but with driver 4614 is working.
JDink
I can't install this driver for some reason. It tells me that my computer does not meet the minimum requirements.
CCris2
New Contributor II
Be sure that you downloaded the version for 64 bit Windows. I checked the driver and Intel HD 4600 is supported and it should work, unless there is something customized on your Notebook.
You can try to uninstall the driver and install the new one, and even try to install it manually as driver update from System in Control panel.
Hello IHateJava,
I understand Doom 2016 crashes a few moments after launching.
Let me apologize for any inconvenience this issue may be causing to you.
I would like you to try reinstalling the graphics driver. Please download this graphics driver https://downloadmirror.intel.com/26682/eng/win64_154034.4624.zip https://downloadmirror.intel.com/26682/eng/win64_154034.4624.zip
As soon as the graphics driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters -> Intel HD Graphics -> Driver tab -> Uninstall -> Select the check box Delete the driver software for this device -> OK, restart the computer, and then reinstall the graphics driver with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
If issue persists please access the BIOS of the notebook and check if there is any option to increase video memory. The issue you are currently having might be because the system might not have enough video memory available. This link will show you how to enter the BIOS https://support.hp.com/gb-en/document/c00034791 https://support.hp.com/gb-en/document/c00034791
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Let me know if issue persists or not.
Fred D.
JDink
Hi Fred
Manually installing the driver did not work. It refused to install, saying it is not compatible with my version of windows. Is there a driver that supports Windows 7?
CCris2
New Contributor II
I checked again and it seems that that driver supports Intel HD 4600 only in windows 10 ...
And Fred that is not a memory problem because even with 16 GB of RAM with the last driver 4678 on Intel HD 530 on windows 8.1 the game freezes and with driver 4614 the game runs perfectly fine.
Also the game runs on windows 10 with both drivers so it seems like is more like an optimization for windows 10, and older windows versions are not working with that optimization on the last driver.
I checked HP drivers and they are extremely old.
IHateJava on windows 7 the driver assigns about 1.7GB for the igpu and on windows 8.1 and windows 10 about 4GB. I don't think that this should have anything with the crash you get but you can try windows 10 if you can and see if it works with the latest driver.
For windows 7 i don't think that will be to much support because the video memory limitation. On windows 10 if your system has like 16GB RAM you can get assigned 8GB for video memory ...
JDink
Oh well. I'm not sure I want to install Windows 10, but thanks for the help.
Hello IHateJava,
Would you please try installing this other driver? https://downloadmirror.intel.com/26229/eng/win64_154028.4501.zip https://downloadmirror.intel.com/26229/eng/win64_154028.4501.zip
Please install that driver with the same steps of the YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
Fred D.
JDink
Hi. This driver gives me the same issue. I downloaded the .zip that says it is for Windows 7, 8, and 10 64 bit. I followed the steps in the video, and the installation failed again, saying it does not support this version of Windows. The driver list shown did not list Intel HD Graphics 4600, so I selected the generic one.
Hello IHateJava,
This is another version of the same graphics driver, would you please give it a try? https://downloadmirror.intel.com/26228/eng/win64_154028.4501.zip https://downloadmirror.intel.com/26228/eng/win64_154028.4501.zip
Fred D.
JDink
I tried this driver too. Same result. Not supported.
I have a YouTube video showing what i did exactly, if that is any help.
Hello IHateJava,
If possible I would like you to try the graphics driver HP* provides on their website for your specific computer model. This procedure is just to check if this is or not a regression issue in our latest graphics driver. You can download the graphics driver from this link http://ftp.hp.com/pub/softpaq/sp72001-72500/sp72370.exe http://ftp.hp.com/pub/softpaq/sp72001-72500/sp72370.exe
If issue persists please attach to this forum thread the DxDiag and DispDiag reports.
DxDiag Instructions:
  1. Click on the "Start Menu" -> Type "DxDiag" -> Press "Enter" -> Wait for the DirectX Diagnostic Tool to finish loading
  2. In the DirectX Diagnostic Tool, click "Save All Information" -> Save the file DxDiag.txt
  3. Include DxDiag.txt as an attachment in the Intel Community Forum
DispDiag Instructions:
  1. Click on the "Start Menu" -> Type "cmd" -> Then a command shell window will open
In the command shell, type "dispdiag -out %homepath%\Desktop\DispDiag-Intel-Issue.dat" -> The command shell will output something similar to "Dump File: C:\Users\[username]\DispDiag-# -# -# -# .dat"
  1. Locate the .dat file on your desktop and include DispDiag-Intel-Issue.dat in the Intel Community Forum
Fred D.
JDink
The driver given did not install, so here are the requested files.
Hello IHateJava,
Thanks for the additional information you sent to me.
I will do further research and then I will post information on this forum thread.
What is the exact behavior of the computer when the game crashes? Do you get any error message on the screen?
Fred D.
JDink
There is crash info from the game. I've attached a zip with the crash logs and such. I hope this is of use.
Hello IHateJava,
I will do further research about this, and then I will post information on this forum thread.
Fred D.
Hello IHateJava,
After doing additional research I found out that Doom 2016 might not work correctly on Intel HD Graphics 4600 due to the amount of video memory the graphics controller supports.
What I can recommend is contacting the company that developed the game in order to check if they can provide a patch or workaround for this.
Fred D.
Hello IHateJava,
I was wondering if you had time to contact your game developer team for additional patches or updates for the game.
Allan J.
JDink
Hi
I have been informed by the game publisher that you need 2 gigabytes of video memory to run the game. Since I have 14 GB of RAM, I assumed that more would be assigned to the integrated graphics. I guess I was mistaken. Is there any way I could dedicate more RAM to my graphics card, manually?
Hello IHateJava,
Thank you for updating this thread. The BIOS should provide some type of video memory configuration, this is usually located under video settings. I understand Windows® 10 will let the computer use up to 2048MB of video memory.
Have you tested this game on Windows® 10?
See this https://www.intel.com/content/www/us/en/support/graphics-drivers/000020962.html link for Graphics memory on Windows® 10.
Allan J.
