23852 Discussions
Downgrading Driver
Hi, recently got a Gateway computer with i7 6GB HD 3000 I am trying to lower to my driver to version 15.22.1.2361 because that will hopefuly run Mass Effect 2. So I tryed to install it and at the end of the setup it says that thisis not validated for my computer.Can anyone help with lowering my driver?
DArce
Valued Contributor III
You can try uninstalling the driver that is currently loaded. That is done through the control panel, under programs and features, locate the Intel(R) Graphics Media Accelerator driver or anything similar and remove it.
Then try again. If the issue persists you can try loading the driver with the "have disk" installation instructions available here:
http://www.intel.com/support/graphics/sb/CS-022355.htm http://www.intel.com/support/graphics/sb/CS-022355.htm
DArce
