23716 Discussions
Download timed out error -
learner999
I tried downloading it multiple times in different ways but ran into the same error. I'm running Windows 10. I keep getting a message that I have an update from Intel and when I try to download I have this error. Tried different browsers and also with and without VPN but no luck. Appreciate it if someone could respond with a working solution. Thanks much in advance.
Stefan3D
Intel updated the download link for the new driver, but apparently not yet in IDSA
Try here (unless you have a Skylake processor):
https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html
Stefan3D
learner999
Thanks! It worked.
Jean_Intel
Hello learner999,
Thank you for posting on the Intel️® communities. We are glad to know that the issue is solved after following the recommendations from @Stefan3D.
However, we would like to further investigate this matter internally. If you would like to help us research this matter internally, you can share with us the following:
Jean O.
Jean_Intel
Hello learner999,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello learner999,
Best regards.
Jean O.
