23854 Discussions
Driver 4849, Vulkan API bug?
Parapele
Hello everyone!
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Driver 4849 made downgrade of Vulkan to 1.0.0, programs that check level of API does not run. Intel control panel reports 1.0.0 level on 4849 driver instead 1.0.61.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
custom GIGABYTE H110M-S2H i3-6100
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
only HD 530
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
SAMSUNG SyncMaster 204B
How much memory [RAM] in the system (see note2 below).
8Gb DDR4 2133
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
Hardware Stepping (see note1 below).
<td rowspan="4" style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; border-right: sol...
Hello Parapele,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with the Vulkan® API after updating the graphics driver to version 4849.
Thank you for the information provided. We are currently reviewing this information to be able to find a solution for you, and we will reply to you again as soon as we have more information.
Xavier A.
Hello Parapele,
We are about to proceed with a laboratory test to replicate this issue.
In order to reproduce this issue, should we just launch the emulator without loading any ROM? Can you point us to a place where we can obtain a legally approved ROM?
Xavier A.
Parapele
Hi! You don't need games. Xenia don't will launch at all, it will make xenia.log in folder with exe after error message. RPCS3 will launch but in GPU option Vulkan missing on 4849. Screenshot was made on 4815.
Hello Parapele,
Thank you for the information provided. This will be helpful in our research.
Xavier A.
Parapele
Hi! I just want you know that i just made update of Windows to 16299.64 version and decide install 4849 driver again and nothing change.
New diagnostic files from new version of Windows and 4849 driver.
Hello Parapele,
Thank you for the information and for your patience.
We tried to replicate the issue in our laboratories, but we did not get the expected results. The emulators did not work properly, but we did not get the same results as you.
However, we will be escalating the issue to the next level of support to be able to look for a solution for you, and we will reply back with more information as soon as possible.
Xavier A.
Parapele
Hello. It's a strange that you said "emulators did not work properly", they work or they don't. If driver upgrades Vulkan version up to 1.0.61, emulators will work properly, and i pretty sure its your case. If Xenia launches - its working. If RPCS3 in option has Vulkan - its working. You not can just put Blu-Ray disk and play games, read https://rpcs3.net/quickstart FAQ please. I found http://vulkan.gpuinfo.org/displayreport.php?id=2172 this, looks like its a scan Intel HD 530 with 4849 driver and it actually has 1.0.61 version of Vulkan, why driver downgrades for me... I can't believe, am alone with this problem. I will leave Vulkan API scans from https://www.techpowerup.com/download/techpowerup-gpu-z/ GPU-Z and http://www.geeks3d.com/20171031/gpu-caps-viewer-1-37-0-released/ GPU Caps Viewer.
MSchm21
Valued Contributor I
I have exactly the same issue on my i7-7700k with HD Graphics 630. Vulkan reports 1.0.0 which is clearly a bug on Intels side.
Hello Parapele,
Thank you for your patience. After escalating this situation, I have been told to request you to post the issue in the next thread for further assistance: https://communities.intel.com/thread/117264 https://communities.intel.com/thread/117264
Within that thread you will be assisted by a representative currently in charge of issues related to Vulkan®.
Xavier A.
MSchm21
The issue has been fixed in driver 4877 for me.
