23782 Discussions
Driver Problem
noach_hw
I am using 12th Gen Intel(R) Core(TM) i5-1235U 1.30GHz.Ekran görüntüsü 2024-12-22 010518.pngEkran görüntüsü 2024-12-22 010518.png
I am updating the driver in the image I showed below and it is updated.
I do a clean driver update while installing. But when I turn on the computer the next day it goes back to the old version(101.4255). I'm tired of updating the driver every time. I need help.
MUC
Honored Contributor I
Please try as follows:
  1. Install the latest driver from the Intel download page.
  2. After rebooting the computer, let Windows search for updates. An old Intel driver will be found and installed.
  3. After rebooting the computer again, manually install the latest Intel driver again but without the "clean install" option.
  4. After completing the installation and rebooting, the driver should remain.
noach_hw
I will download it again as you said, but is there a possibility that it will revert to the old version when I turn on the computer tomorrow morning? Because the driver is already being updated. The problem is that it will revert to the old version.
LT7879
Hi @MUC I also have the same issue. Have tried your method in 2 laptops, but after finish installing the latest intel driver, windows update will detect the old one and install the old one.
JedG_Intel
Hi noach_hw,
I'm following up to check if you require further assistance. Please let me know so I could determine the next best course of action.
Jed G.
JedG_Intel
Hello noach_hw,
Jed G.
