23257 Discussions
Driver not updating to newest
SLezo
I'm not exactly sure if the Version number and date are simply not updating, or if it simply didn't update.
So I just acquired Windows 10, and went ahead and downloaded the new Windows 10 Driver for 4th Gen Processors (4600)
I did the manual updating, which is manually searching -> Have disk -> Pick the ighdl64 file. after all the process, and to ensure the Update takes place, I restarted my PC.
I checked the Driver, and to my surprise, it's still the 7/17/2015 version, and not the new one.
Is there any solution to forcing the driver to update, or should I just simply let the version number and date update?
I appreciate the sincere replies!
RGras1
Is there a reason that you can't run the installer? I've updated with it and it has done it's work very nicely.
SLezo
When I last checked there was only a .zip version of the new Driver.
And not only that, but after the driver "Fake-installed", my PC keeps getting resetted with video_tdr_failure igdkmd64.sys
YPira
Same here with an HD 4400, version 10.18.15.4256 from 17/07/15, also goes BSOD the same way, but only when I launch some -and maybe all- games, with a flickering black screen. Text and thumbnails look blurry and start menu also gets distorted when I open the "all apps" list .
MMado1
I am having the same problem, shortly after installing Windows 10 on a HP Envy with Intel HD Graphics 4600 the display started having lines everywhere (Don't know what the technical term is, don't care to look it up) so I went to Google to see if there was a driver for Windows 10, and found it. I first unzipped it to a folder on my desktop and ran the setup.exe, which went through the process of installing and rebooting, only to not fix the problem. Likewise, the driver still listed as being from 7/15/15, instead of the 7/28/15 the Win 10 driver is supposed to be. I attempted to manually install it, with little success. I am using a VGA cable since that is what it came with and was happy with it, not sure if getting a DVI cable and using that would help or not.
MMado1
Ok, looks like the problem is actually my monitor and not the driver, as I plugged in an older monitor and had no line problems. So unless Windows 10 is damaging monitors it appears my monitor broke shortly after installing Win 10.
MBara6
yes we all have the same problem..the driver isn't upgrading to the latest version of windows 10 .. and the graphic card every second stop working even when i'm not playing a game..when open a game a blue screen come with error message says "the pc ran itno an error VDR-TDR-FAILURE igdkmd64.sys" please fix that problem.
JIglé
My drivers seem to be stuck at the 17/07/15 version too. (or 07/17/15 version for the US) Which for me is this one: 10.18.15.4256.
Though what happens to me is quite diferent without the drivers (before having intel HD graphics 4600 active) my display is fine though I can't play any game at all (which would make sense), but the screen is fine on desktop. When I install the drivers my screen goes pink/green flashing between that and its normal colors, even in game.
RGras1
What happens if you all go to Control Panel -> Uninstall a Program -> Intel HD Graphics, then goto device manager, make sure the drivers are uninstalled else uninstall them yourself (and tick the option 'remove driver files'), restart, then run the setup.exe from the .zip, restart?
I assume you all use the following package (x64) (?): https://downloadcenter.intel.com/download/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit Intel® Download Center
MBara6
yes we all use the package x64 its the only here ..and ok ill try what you say..ill reply soon.
MBara6
well..i did what you have said and that didn't work actually..
MKva
same to me on build 10240 even after the driver update
Intel HD 4600 driver 10.18.10.3379.01 (old driver, works perfect ) (From ASUS)
Intel HD 4600 driver 15.40.4.64.4256 (new driver, doesn't work ) (from Intel)
my notebook:
Asus ROG G750JM
MBara6
yea but Intel isn't saying anything like there is a fix coming or something like that
SLezo
We have to realized that this'd be inevitable
It's Day 1 of W10 and the new driver, it's the worst day we could've picked for getting Windows 10.
Hopefully in a close time, Windows 10 will have a fix and a new Driver will be out.
grasmanek94 I've tried Uninstalling from control panel, but once it uninstalls, my screen starts to spass with the RGB Colors, putting the PC to sleep with a macro fixes that, but hopefully sleeping the PC after the driver uninstalls doesn't affect anything.
I'll try verifying in Device manager as well.
What's the exact sequence I have to follow in Device Manager?
-> Display Adapter -> HD 4600 (Left click) -> HD 4600 Properties -> Driver -> Uninstall -> Delete Driver software from this system box Checked?
RGras1
NChanto, yes that is the correct sequence, if you are unable to view your screen during the steps I suggest to use remote control software, like TeamViewer, that could make everything easier.
SLezo
I mean, putting the PC quickly to Sleep and fix the screen spass color will affect nothing, right? The process won't be reverted or any possible damage?
I am interested in trying TeamViewer, but I just want to know if putting my PC to sleep quickly doesn't affect anything critical to the process.
Darwin_B_Intel
Hello NChanto,
I would like to refer to your original post.
When the first driver versions for Intel Graphics Controllers to work with Windows 10 were released it was expected to experience issues. Even though there is a development phase in which drivers are tested before a new operating system is released there are always areas that are not seeing until users put hands on the new products.
We have released different drivers since then and right now we have available versions 15.40.4.64.4256 and 15.40.7.64.4279 (latest).
We encourage customers to do the driver update manually by downloading the file from the computer manufacturer or Intel web sites. We also recommend to uninstall the previous driver before installing the new one.
Here is the link for you to download the latest Windows 10 driver for your Intel® HD Graphics 4600 in case you want to try it, note that now we have an *.exe file:
https://downloadcenter.intel.com/download/25308/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-4th-Gen-Windows-10-64bit https://downloadcenter.intel.com/download/25308/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-4th-Gen-Windows-10-64bit
Please bear in mind that our drivers are generic and we don't guarantee that they will work with all products. Third party motherboard manufacturers and computer makers usually customize their products and develop proprietary drivers. If you have problems using Intel drivers we recommend getting them from the motherboard or computer manufacturer.
In regards of your last question, there should be any problem at all with the CPU.
