23828 Discussions
Driver "High Precission Event Timer"
jlero
After a check of my "system" devices, I have just discovered the error picture attached:
My Operating System
Windows 7 Home Premium SP1 64-bit
Computer Type: Portable Model SATELLITE C670-1DT.
The Technical Support I send two drivers to correct this problem, next TCA0062400E. exe and TCA0058700A .exe .
But nothing was correct, how can I fix it.
Thanks for your help.
Best regards.
Jean-Pierre Leroux.
AP16
Valued Contributor III
You can safely disable HPET in laptop BIOS, it is not in use in Windows 8 upwards.
jlero
I'm running Windows 7 and HPET is not in my BIOS. Do I turn off from the device manager?
AP16
You can just ignore that error, as i said, Windows will not use HPET by itself.
jlero
Can you explain to me the nature of this error, which was not there before.
AP16
Windows Device manager have a "Resource" view mode. Switch to it and expand the "Memory" part. Scroll down to HPET area and take a look around, what device takes the same address range.
