22828 Discussions
Driver updates still don't work on i7-4500U 1.80 GHz +Nvidia Gt 750M, scaling issue still exists
i tried every possible solution I could find, reinstalling every driver multiple times etc. The issue with Counter Strike running with black bar still exists. My CPU is not stated in the list of the release note. What to do now?
Hello polszterdani,
Thank you for contacting the Intel community.
Is this a switchable graphics computer?
What is your system model? You can attach your system information; you can use the ISSU to get your system information.
Intel SSU (System Support Utility) (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility😞
Download Intel® System Support Utility
  1. Download the utility
  2. Run the exe and select 'Scan'
  3. Save and include as an attachment in the Intel Community Forum
Ivan.
Thanks for the quick response. it is an Acer Aspire V5-573G.
Thank you for the information and I apologize for the late reply.
I just want to make sure you have the latest graphics driver; you can download the latest Intel® generic driver here:
https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81497 Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
After you install the graphics driver, check if your still have the issue, if so, try the following:
Open Intel HD Graphics Panel (ctrl>Alt>F12), open the display menu, switch to 1024x768 and make sure the "Maintain display scaling" button is ticked (not scale full screen), open game while in this mode. Please try it as it shows on the image below:
Please check the recommended game settings at the picture below:
If the issue persists, try with the same resolution on your monitor and on the game.
I hope this can help.
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
