23854 Discussions
Drivers
TTafi
Hi. Where can I get graphic drivers for this type of processor: Intel(R) Celeron(R) CPU 2.50GHz. The ones I have been downloading could not install due to an error which was saying the system does not meet minimum requirements.
Hello Tatenda,
Thank you for joining the Intel communities.
You can run the http://www.intel.com/content/www/us/en/support/detect.html Intel® Driver Update Utility, this software will find the driver for you, if not please reply with the Dxdiag files to better assist you.
In the "Run" window, type "dxdiag" and click OK. A "DirectX Diagnostic Tool" window should pop up. In the window that has now appeared choose "Save all information" After you've saved the file, please attach it to your thread.
Best wishes,
Ivan
I'm just following on this thread to ask you if you still need further assistance.
Ivan
