23270 Discussions
Dual monitor problem with HD4000 on centos 6.5
zsunn
I got a ASUS laptop model B400A, with intel ivy bridge i5 3317u processor and hd4000 graphics.
Recently I installed centos 6.5 64bit and dual monitor fail to use.
A externl LCD monitor was connected via HDMI port to the laptop, when I boot centos without external monitor, everything just fine, and after I log in to the OS and then connect the HDMI port , everythig just worked perfectly.
But, if I boot the os with HDMI port connected, the log in screen didn't show up , laptop internal screen is black and only wallpaper show up on the external moniter, so I can't login to OS . It seems that internal screen didn't configured properly, but I don't know how to configure it .
[root@localhost ~]# lsb_release -a
LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Distributor ID: CentOS
Description: CentOS release 6.6 (Final)
Release: 6.6
Codename: Final
[root@localhost ~]# uname -a
Linux localhost.localdomain 2.6.32-504.16.2.el6.x86_64 # 1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost ~]# lspci
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
00:04.0 Signal processing controller: Intel Corporation 3rd Gen Core Processor Thermal Subsystem (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller # 1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller # 2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.4 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 5 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller # 1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
00:1f.6 Signal processing controller: Intel Corporation 7 Series/C210 Series Chipset Family Thermal Management Controller (rev 04)
02:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235 (rev 24)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01)
Anybody can help?
Allan_J_Intel1
Please check for Intel graphics drivers for Linux here: https://01.org/linuxgraphics/ Home | Linux Graphics
Allan.
zsunn
Allen, thanks for your reply.
I've ever checked the site, but centos 6.5 offered a very old kernel 2.6.32, I cannot find any linux graphics driver on that site matches 2.6.32 kernel, any advise on this?
Allan_J_Intel1
You can try any of the Linux support groups to see if there are any drivers available that will provide you with the functions you require.
https://www.centos.org/forums/ CentOS • Index page
Allan.
