22816 Discussions
Dual monitor with HDMI keeps connecting and disconnecting in Linux with Ultra 7 255H
Shaun2
Hi, I'm using a laptop with Intel Ultra 7 255H. When I use Linux (Linux mint), once I connect an external monitor via HDMI cable, the monitor keeps switching and flickering. However, when I use only the external monitor (i.e., with the laptop lid closed), everything works normally. Therefore, the HDMI cable is not the issue. And when I use a dual monitor in Windows, everything is also fine. I have tried updating the kernel and installing Ubuntu. However, the issue persists.
Please note the refresh rate of my internal monitor is 120 Hz, whereas the external is 60 Hz. I don't know if this is the cause of the problem. I have also changed the refresh rate of the internal monitor to 60. However, once I plug in the HDMI cable, the refresh rate becomes 120 Hz.
Sorry about my English. I also upload a video. https://drive.google.com/file/d/1hKYB9S ... sp=sharing
Here is my system and hardware information
System:
  Kernel: 6.14.0-33-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
  Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
    Distro: Linux Mint 22.2 Zara base: Ubuntu 24.04 noble
Machine:
  Type: Laptop System: MECHREVO product: CODE Series v: Standard serial: <superuser required>
  Mobo: MECHREVO model: CODE Series-X5AR4NAG v: Standard serial: <superuser required>
    part-nu: 0001 uuid: <superuser required> UEFI: American Megatrends LLC. v: N.1.13MRO01
    date: 05/30/2025
Battery:
  ID-1: BAT0 charge: 99.2 Wh (100.0%) condition: 99.2/99.2 Wh (100.0%) volts: 17.5 min: 15.5
    model: standard type: Li-ion serial: <filter> status: full
CPU:
  Info: 16-core model: Intel Core Ultra 7 255H bits: 64 type: MCP smt: <unsupported>
    arch: Arrow Lake rev: 2 cache: L1: 1.6 MiB L2: 28 MiB L3: 24 MiB
  Speed (MHz): avg: 1624 high: 4428 min/max: 400/5100:4400:2500 cores: 1: 1601 2: 1251 3: 400
    4: 1800 5: 1400 6: 1762 7: 879 8: 980 9: 1001 10: 4391 11: 400 12: 3802 13: 400 14: 4428 15: 1100
    16: 400 bogomips: 117964
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel Arrow Lake-P [Intel Graphics] vendor: Tongfang Hongkong driver: i915 v: kernel
    arch: Gen-15 ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:7d51 class-ID: 0300
  Device-2: SunplusIT HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    bus-ID: 3-3:2 chip-ID: 2b7e:b663 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 24.1.6 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26") s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: AOC 27B1 serial: <filter> res: 1920x1080
    hz: 60 dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27") modes: max: 1920x1080
    min: 720x400
  Monitor-2: eDP-1 note: disabled model: BOE Display NE153QDM-NY1 res: 1920x1080 dpi: 198
    size: 329x206mm (12.95x8.11") diag: 388mm (15.3") modes: 2560x1600
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: PPA glx-v: 1.4 direct-render: yes
    renderer: Mesa Intel Graphics (ARL) device-ID: 8086:7d51
Audio:
  Device-1: Intel vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
    chip-ID: 8086:7728 class-ID: 0403
  API: ALSA v: k6.14.0-33-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
  Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3 chip-ID: 8086:7740
    class-ID: 0280
  IF: wlp0s20f3 state: up mac: <filter>
  Device-2: Motorcomm Micro. YT6801 Gigabit Ethernet vendor: Tongfang Hongkong driver: N/A pcie:
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 2c:00.0 chip-ID: 1f0a:6801 class-ID: 0200
Bluetooth:
  Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    bus-ID: 3-10:7 chip-ID: 8087:0026 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11
    sub-v: 4395 hci-v: 11 rev: 4395 class-ID: 7c010c
Drives:
  Local Storage: total: 953.87 GiB used: 33.53 GiB (3.5%)
  ID-1: /dev/nvme0n1 model: YMTC PC41Q-1TB-B size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: YM11D332 temp: 27.9 C scheme: GPT
Partition:
  ID-1: / size: 641.54 GiB used: 33.48 GiB (5.2%) fs: ext4 dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 96 MiB used: 55.3 MiB (57.6%) fs: vfat dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s lanes: 1
    chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 20 Gb/s lanes: 2 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s lanes: 1
  Device-1: 3-3:2 info: SunplusIT HD Webcam type: video driver: uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s lanes: 1 power: 500mA chip-ID: 2b7e:b663 class-ID: 0e02 serial: <filter>
  Hub-4: 3-5:3 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s lanes: 1
    chip-ID: 05e3:0610 class-ID: 0900
  Hub-5: 3-6:4 info: Manufacturer hub ports: 4 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
    chip-ID: 0a05:7211 class-ID: 0900
  Device-1: 3-6.2:5 info: Logitech G102 LIGHTSYNC Gaming Mouse type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 300mA
    chip-ID: 046d:c09d class-ID: 0300 serial: <filter>
  Device-2: 3-6.3:6 info: CHERRY G83 (RS 6000) Keyboard type: keyboard driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 1.5 Mb/s lanes: 1 power: 100mA chip-ID: 046a:0011 class-ID: 0301
  Device-3: 3-10:7 info: Intel AX201 Bluetooth type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s lanes: 2 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-7: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2 speed: 5 Gb/s lanes: 1
    chip-ID: 05e3:0620 class-ID: 0900
Sensors:
  System Temperatures: cpu: 39.2 C mobo: N/A
  Fan Speeds (rpm): N/A
Repos:
  Packages: pm: dpkg pkgs: 2152
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/cappelikan-ppa-noble.list
    1: deb [signed-by=/etc/apt/keyrings/cappelikan-ppa-noble.gpg] https: //ppa.launchpadcontent.net/cappelikan/ppa/ubuntu noble main
  Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
    1: deb [arch=amd64] https: //dl.google.com/linux/chrome/deb/ stable main
  Active apt repos in: /etc/apt/sources.list.d/kisak-kisak-mesa-noble.list
    1: deb [signed-by=/etc/apt/keyrings/kisak-kisak-mesa-noble.gpg] https: //ppa.launchpadcontent.net/kisak/kisak-mesa/ubuntu noble main
  Active apt repos in: /etc/apt/sources.list.d/kobuk-team-intel-graphics-noble.list
    1: deb [signed-by=/etc/apt/keyrings/kobuk-team-intel-graphics-noble.gpg] https: //ppa.launchpadcontent.net/kobuk-team/intel-graphics/ubuntu noble main
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb https: //mirrors.aliyun.com/linuxmint-packages zara main upstream import backport
    2: deb http: //mirrors.aliyun.com/ubuntu noble main restricted universe multiverse
    3: deb http: //mirrors.aliyun.com/ubuntu noble-updates main restricted universe multiverse
    4: deb http: //mirrors.aliyun.com/ubuntu noble-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Info:
  Memory: total: 32 GiB note: est. available: 30.88 GiB used: 4.2 GiB (13.6%)
  Processes: 379 Power: uptime: 33m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
  Compilers: gcc: 13.3.0 Client: Cinnamon v: 6.4.8 inxi: 3.3.34
KennethB_Intel
Hello Shaun2,
Thank you for reaching out to the Intel Community Forum. I understand that you are experiencing flickering and disconnection issues with your external monitor when using Linux Mint and an Intel Ultra 7 255H processor. I would like to ask a few questions to better understand the situation and assist you further:
  • How often does the flickering and disconnection happen? Is it random, or does it follow a pattern?
  • Aside from the steps you already tried, have you attempted any other troubleshooting methods?
  • Could you confirm the exact model of your monitor and the HDMI cable version you are using?
  • Could you please provide us the SSU logs of your system? Please download Intel® System Support Utility for the Linux* Operating System and scan your system so I can further check this.
Please reply with the details at your earliest convenience so I can continue to assist you.
Thank you.
Kenneth B.
