23854 Discussions
Dual monitors not working
MShir2
I have a MSI Z87-G43 motherboard with i5-4670K CPU. When I connect two monitors to the onboard graphic card (1xVGA and 1xDVI) both screens are black, there seems to be a connection when the pc is turned on (i.e it says "DVI, or VGA") but nothing actually shows.
If I only connect one of them then it all works fine. If I connect a second screen while in Windows 8 the computer will hang (no ctrl+alt-del, no nothing).
The setting for dual monitor is also enabled in the BIOS.
The graphics drivers and BIOS are updated.
Kevin_M_Intel
Hi mechk,
Can you please post you dxdiag report and your graphics report?
To get dxdiag report: Start> type dxdiag> Click on save.
To get the graphics report: Open the Graphics Control Panel> Options> Information center> Save.
