22916 Discussions
ERROR: Some futures are not supported on non-Intel adapters
DatG
Intel UHD 620
Windows 10 64 bit Home 2004
While I was installed Intel Graphics Command Center, it showed: "Some futures are not supported on non-Intel adapter"
What should I do?
LeonWaksman
Hi @DatG
Probably you have an other Graphics Adapter/Chipset installed on you system (AMD, NVIDIA,...).  If this is the case, you need to do nothing. The IGCC can't control other adapters and the missing function can be controlled by those adapters Control Panels.
Leon
