23769 Discussions
Enable Custom Aspect Ratios
RCox3
My post is related to this same issue
/message/409224 https://communities.intel.com/message/409224
I've tried every resolution including custom resolutions, and the screen is always either too tall or too wide on HDMI. Am I too believe that the " custom aspect ratios " is not available for every device or driver version in Intel HD Control Panel. I have the option on my other laptop with the Graphics and Media control panel, though it seems random when it actually enables. Seems like a lot of hassle to go through for what should be a simple and easily or already enabled feature.
Hello Sonic98,
Thank you for contacting the Intel community.
This is most likely a limitation by your computer manufacturer on this specific driver version that you have installed, we can try installing the latest graphics driver version, you can download it here:
https://downloadcenter.intel.com/download/26682/Intel-Graphics-Driver-for-Windows-15-40-?product=87261 Intel® Graphics Driver for Windows* [15.40]
If you get an error installing this driver, I suggest you to uninstall the old one and install this new version /Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1* manually.
I hope this can help.
Ivan U.
RCox3
I'll try installing drivers again
Thank you Sonic98, please let me know how it goes.
Ivan U.
RCox3
it looks like my posted more than once. I don't know if we need to merge those threads or something
RCox3
Ok I'm all the way up to 4624 and I got the "maintain display scaling" but I have not gotten "custom aspect ratios" or the sliders around the preview image. Updating has not fixed my problem, and I have tried every resolution including some custom ones.
Hello Sonic98,
I'm sorry that your still have this issue.
I can't confirm that this option is available with this driver version, this is a limitation by your computer manufacturer, you can try contacting you computer manufacturer to see if they have a new BIOS version for your system that it might help but I can guarantee it.
Ivan U.
